550 F2 stopper bracket
Topic: 550 F2 stopper bracket (Read 2940 times)
Sesman
April 28, 2021, 01:48:27 PM »
Any tips on how to get those pesky little rubber ‘stopper brackets’ back into the instrument plate. I don’t want to be too brutal as they are the originals.
mickwinf
Re: 550 F2 stopper bracket
April 28, 2021, 02:13:01 PM »
warm the rubber to soften, maybe use silicone grease or similar as lube.
K2-K6
April 28, 2021, 02:49:51 PM »
As above for me.
I also use silicone grease on things like side panel rubbers etc to make them easy without cracking the mounts.
Sesman
April 28, 2021, 02:52:51 PM »
Thanks for the responses. Sorry to disappoint, but tried both them methods and failed. I will persevere....
Sesman
April 29, 2021, 07:47:11 AM »
Ok, silicone and brute strength it is...I’ll get the wife to do it
Sesman
April 30, 2021, 09:18:45 AM »
Ok...the solution. Use 5lb fishing line. Place a good few winds of fishing line round the mushroom head, pass both ends back through the greased hole and pull while twisting.
This method is needed if the ham fisted owner has chewed the sharp end of the stopper through clumsy use of pliers...ahem
