SOHC.co.uk Forums > SOHC Singles & Twins
Cb 200 rings
Bryanj:
Dont do it they wont be round, you need standard rings
shifter:
Many thanks Guys for your input, wasn’t keen on the expense of a rebore (negative equity come to mind)as there wasn’t any wear in the bore, perhaps go back to standard, it’s no show pony and won’t be commuting, Thankyou again...
AshimotoK0:
--- Quote from: shifter on May 24, 2021, 12:53:16 PM ---Many thanks Guys for your input, wasn’t keen on the expense of a rebore (negative equity come to mind)as there wasn’t any wear in the bore, perhaps go back to standard, it’s no show pony and won’t be commuting, Thankyou again...
--- End quote ---
If you think there is no significant bore wear and you try a new ring, the gap may be in tolerance ... which should be OK. 6 thou is the absolute minimum for a perfect bore and new ring.
shifter:
Ash , I can see your point , “ But ,“ to try your a standard ring means they very expensive £70 genuine ,for a just a try to engine out every time , it was just a thought from the forum ,I have heard a few competition lads have tried it. I’m from the West Country and are very frugal here 😎, Thankyou all again from your input
Bryanj:
Its a sall bore and when you compress the ringextrait goes out of round, if it was a 3" Ford bore it would be a lot less noticable
Navigation
[0] Message Index
[*] Previous page
Go to full version
