SOHC.co.uk Forums > CB350/400
Decals
<< < (2/3) > >>
element137:
Slightly off topic - what front fork/front/brake set - up are you running on that ?
allankelly1:
--- Quote from: element137 on May 25, 2021, 02:11:44 PM ---Slightly off topic - what front fork/front/brake set - up are you running on that ?
--- End quote ---
Hi
Forks discs and calipers are off a cb400n super dream but with 50mm removed from the stanchions as standard cb400n are too long
Also hub is an original CB400F hub so I can run a standard spoked wheel but the discs are drilled and spaces added to fit the super dream discs
Lastly running a super dream  speedo drive but fitted the CB400F hub with a custom speedo drive as with this change speedo drive is in. The opposite side
Happy to share more details if you are looking at this mod
Best wishes Al
allankelly1:
--- Quote from: Oddjob on May 25, 2021, 06:57:57 PM ---The brake lines look nice, who made those up?
Also the headlight bracket look good as well, someone on here looking for a decent set so some details on those would be good. They look well made.
--- End quote ---
Hi
Brake lines are Venhill
The headland bracket was from eBay
And the horn set up is pure RD350LC with a custom printed horn cover
Best wishes Al
allankelly1:
Lovely chubley
Hope tank look as good
Before lacquer
After lacquer
philward:
Looks great Allan
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
