SOHC.co.uk Forums > CB500/550
Source of quality top end gasket kit for CB550F in Europe
alexdecker:
I ended up using a Vesrah complete kit for the 550F, and that solved all my problems. Must've been a faulty kit or faulty installation with the old kit :)
Thanks for the help!
Bryanj:
ALL newer gasket kits need thicker O rings at the oil feed through head gasket as the new asbestos free head gaskets are thicker, also a common leak is where the brackets the cam cover end caps bolt to are held to the head, there is supposed to be a soft alloy washer between bracket and head
alexdecker:
--- Quote from: Bryanj on July 27, 2021, 09:58:17 AM ---ALL newer gasket kits need thicker O rings at the oil feed through head gasket as the new asbestos free head gaskets are thicker, also a common leak is where the brackets the cam cover end caps bolt to are held to the head, there is supposed to be a soft alloy washer between bracket and head
--- End quote ---
Yeah so me Vesrah kit didn't hold up for long before the leak returned. Do you know of any kit that has thicker O-rings, taking the thicker head gaskets into account?
- Alex
Bryanj:
Nope, just get thicker O rings
deltarider:
Decades ago a Dutch Honda mechanic, specialized in old CBs told me he used Kawasaki O-rings for this that are slightly thicker. I don't know which however.
Navigation
[0] Message Index
[*] Previous page
Go to full version
