SOHC.co.uk Forums > CB350/400
400/4 Engine noise, bodges and Primary chain
Fourplay:
--- Quote from: Nurse Julie on June 16, 2021, 08:10:27 AM ---Those drilling marks where the filer sits are standard, we all have them to a greater or lesser degree on our engines. There are quite a few in various places all over the engine, so nothing to worry about.
There is alway a bit of side play on the primary chain and as for the engine noise, I would start with giving the carbs a thorough strip and clean, fit new Viton O rings, bench sync and then vaccum sync. How many miles has that engine done?
--- End quote ---
Hello Julie. I bought the bike in April with 39,000 miles 10,000 done in the last 30 years. (have MOTs back to 1991 and receipts for work/parts back to 2006). New pistons fitted in 2006 at 36,000 miles. Receipts for dealer servicing/new parts.
Came with carb rebuild sets, so I know the carbs need sorting. Was putting this off until I was happy that the cam chain/primary chain were okay. But I guess the uneven running at idle may be contributing to the rattle and primary chain slap.
Never owned a four before so much of this new to me.
So as advised I think I will remove the carbs, and try and reuse as much of the original jets etc as possible.
I'll be in touch about the Viton O rings once I've stripped the carbs as I see you sell the Carb screw sets as well ,
Thanks for your help.
Justin
McCabe-Thiele (Ted):
Listening to your noise it does have that sort of uneven running tone to it so Julies far more experienced answer looks very sound to me.
I would also be checking the timing is spot on for both sets of points - gap/dwell.
Nurse Julie:
OK Justin. I know removing and stripping the carbs and syncing is a bit of faffing around but, at least it will either rule out, or not, any engine issues there may be.
K2-K6:
"But what is this all about? Looks like someone has attacked the filter housing with a drill?"
As already indicated above they are present in various places and would seem to be there to facilitate machine clearance for critical machining during manufacturing.
--- Quote from: K2-K6 on June 16, 2021, 09:22:35 AM ---"But what is this all about? Looks like someone has attacked the filter housing with a drill?"
--- End quote ---
If it was a flywheel they would be balancing marks, it's probably something odd like where a robot style machine holds it whilst they stamp the casing marks on the other side during production?
Navigation
[0] Message Index
[*] Previous page
Go to full version
