Author Topic: Ignition problem  (Read 14105 times)
Re: Ignition problem
« Reply #30 on: July 02, 2021, 12:54:54 PM »
I belive odd job is right with his theory
« Reply #31 on: July 02, 2021, 01:25:52 PM »
It doesnt matter which way round the big cables go but it does matter which one the small red goes to which is the one from battery
Offline Maax1200
« Reply #32 on: July 02, 2021, 03:47:17 PM »
Yes, the yellow/red and black wire is "pointing" towards the airbox if that makes sense.
Hopefully a replacement relay will solve everything.
I did have to replace the coils since they where faulty to.
Is it  just random that both coils and starter relay malfunctioned at the same time? Voltage regulator?
Offline Maax1200
« Reply #33 on: July 02, 2021, 04:04:34 PM »
Please kill me now.
« Reply #34 on: July 02, 2021, 07:38:42 PM »
Was that it?
Offline Maax1200
« Reply #35 on: July 02, 2021, 07:53:14 PM »
Was that it?
The reason the bike went dark, yes.🥴 How embarrassing.
I will argue with anyone that the issue with the turn signals and oil lamp was way more complicated. And i fixed it by my selfe.🤪
Thank you for the tip.👍
« Last Edit: July 02, 2021, 07:55:04 PM by Maax1200 »
« Reply #36 on: July 02, 2021, 09:09:38 PM »
Not actually done that one but have seen it before
Offline Maax1200
« Reply #37 on: July 03, 2021, 10:04:16 AM »
Just seemed natural that thats where the wire should be due to the shape of the wire and layout. Even took a picture of it, but after i loosend the terminals with the red wire right above the left terminal. It simply moved over by it selfe. Oh well. Im just glad it was a easy fix.
« Reply #38 on: July 03, 2021, 05:16:00 PM »
Bugger sorting out the self adjusting parts!!
« Reply #39 on: July 03, 2021, 09:10:18 PM »
No Ken, just turning into a gof like me
Offline Maax1200
« Reply #40 on: July 04, 2021, 09:37:14 AM »
Offline Maax1200
« Reply #41 on: July 04, 2021, 09:44:32 AM »
Thank you for all the help.
Replaced the coils and fitted new NGK plug caps. Everything looks ok and i got a nice strong spark. Turn signals and oil lamp is now working.
Now its just the final assembly and the bike should be completed, fingers crossed.
Thank you all again.
/Magnus
