Author Topic: Progress  (Read 4521 times)
Progress
« on: August 15, 2021, 06:45:37 PM »
At last, making some headway with the engine. New bearings, shells, seals, primary chain, primary rubbers, cam chain and chain guides. Rods and crank turn freely and gears engage perfectly. Next engine in frame, head rebuild and a bit on minor porting: mainly cleaning up the casting marks and manifold matching.
« Last Edit: November 27, 2022, 10:10:09 AM by Sesman »
Re: Progress
« Reply #1 on: August 15, 2021, 07:04:03 PM »
Looking good 👍👍👍👍
Offline allankelly1
Re: Progress
« Reply #2 on: August 15, 2021, 07:16:02 PM »
Lovely
Offline heli_madken
Re: Progress
« Reply #3 on: August 15, 2021, 11:08:26 PM »
looks really clean and sharp well done!
Re: Progress
« Reply #4 on: August 16, 2021, 06:14:23 PM »
Nice clean looking engine cases.  :)
Re: Progress
« Reply #5 on: August 16, 2021, 06:22:56 PM »
Thanks, Ted. Just don’t look too closely. Wish I’d taken time to dress down the die cast splatter and general casting debris, but I guess that would then look unnatural.
Pistons and block on today, then into the frame. Just what is the best way to remover carbon from valves?
« Last Edit: November 27, 2022, 10:10:55 AM by Sesman »
Re: Progress
« Reply #6 on: August 16, 2021, 06:24:31 PM »
‘Splatter” and “casting” 8)
Re: Progress
« Reply #7 on: August 16, 2021, 09:44:37 PM »
Thanks, Ted. Just don’t look too closely. Wish I’d taken time to dress down the die cast platter and general caring debris, but I guess that would then look unnatural.
On cars I used to put a valve in my drill then using an old Stanley Knife blade I would run it up & down as the valve rotated - I would finish off with the edge with some folded  Wet & Dry paper being careful not to overdo it.
Re: Progress
« Reply #8 on: August 16, 2021, 10:51:27 PM »
Wire brush in bench grinder is my favourite
Re: Progress
« Reply #9 on: August 17, 2021, 07:17:55 AM »
Yes, I use a brass brush. But was wondering if there was a magical chemical method? As an experiment I tried a piston in the ultrasonic cleaner. Came up like new. I’ll try a valve too.
Re: Progress
« Reply #10 on: August 17, 2021, 07:42:29 AM »
Looking good, another for the brass wire brush on the bench grinder.
Offline paulbaker1954
Re: Progress
« Reply #11 on: August 17, 2021, 07:48:26 AM »
Nice work, Wow wish my garage was that clean!!!
How will you fit those new fangled hubless wheels 😂😂😂
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Progress
« Reply #12 on: August 17, 2021, 11:32:20 AM »
Air hubs…very trick ;D. Actually original DID rims in good nick. Certainly serviceable and will be up for sale if anybody is interested.
Re: Progress
« Reply #13 on: September 14, 2021, 09:39:43 AM »
Creeping forward.
Re: Progress
« Reply #14 on: September 14, 2021, 10:23:07 AM »
Looking really good. When large lumps of the bike get finished and installed it makes a huge difference to seeing real progress.
