General > New Member Introductions
Ride on
<< < (2/2)
McCabe-Thiele (Ted):
At that low mileage I  would dump the fuel give the tank a wash, fill with fresh SUL petrol, fit an inline filter and as has been said clean the jets out.
Old petrol sets like a laquer when a bike is used infrequently then when you run it jets get blocked.
Phil Ward (RIP):
Welcome to the forum. Sounds like fuel and agree with previous post but additionally, check the fuel tap flow - I had recent problems with hesitancy and had a problem with the petrol tank cap not venting AND separately petrol tap not free flowing. As a first check, worth a go prior to carb strip - just take tank off and switch tap on to flow into a bowl - lot easier than a carb strip if subsequently not required.
Ceeby-jeebies:
Thanks for the suggestions. Removed the plugs and they are all blackened, so it looks like it is running rich. How is this best fixed? I’m not much of a mechanic myself…
Nurse Julie:
Middle 2 look not bad, a little lean for my personal liking, the outer 2  are only a tad rich. There is a air/ fuel mixture screw on each carb, you need to see how many turns out each screw is at and then adjust accordingly. It is always better to run slightly on the rich side than lean side.
Nurse Julie:
--- Quote from: Oddjob on August 25, 2021, 04:58:33 PM ---Resistor plugs with resistor caps, not a great idea. Soot on plugs could also be because you've been using the choke a lot to get it started. Take it for a decent run and test them then.
--- End quote ---
Good spot Ken, I hadn't noticed the plugs were resisted, which is pretty amazing. I don't suffer with OCD but resisted plugs and resisted caps gets me up to borderline anxiety levels 😁😁😁😁
Navigation
[0] Message Index
[*] Previous page
Go to full version
