General > New Member Introductions
My bike
<< < (2/2)
PMK:
Did you get the tool kit   :D Yeah Right !!!
Thanks for that.
I'll have a dig to see what I can do about the horns and the plate etc. I think I've got a battery strap lurking about somewhere.
Glad you all like it. When it warms up later today it's service time  ;D  Mmmmmmm tooolllsss
PMK:
Well I got the tools out and went through the bike today.
The tappets needed a spot of adjustment and I tried the Honda way and got comnpletly confused and messed them up. So I did it the other (read as old fashioned) way and turned the engine over until the both were shut after the intake stroke, much better!
The carbs were all spot on and the air filter spanking new. I had to close the points a smidge. The plugs looked a little rusty but none of my plug sockets fitted so that's for another day.
Once warmed through the oil was dropped and the filter changed. I only had a little disaster when the funnel decided to disassemble itself when I was draining the tank.  >:(
Still once it was refilled (2.5 litres doesn't seem like a lot) and a quick roadtest revealed a little more willingness to the engine (which is nice)  ;D
So all that's left is to clean it now !!
Spitfire:
For some reason bike polishing is no longer my favourite hobby, I used to spend hours polishing but now I keep putting it off !
Den
F2 Paul 876:
Hi Paul
Nice bike looks clean and a good mileage.
For your info you all so have got a aftermarket exhaust and looks like Hagon road rear shocks not the standard FVQ's, i have a pair of the Hagons to go on my 1st F2 when its finished. A good mod you have is braided brake lines this makes a big difference's,my 1st F2 has these my 2 nd one has not and you can notice the difference big time. The engine side case should be black,  and there is some seat trim missing, it depends if you wish to go to full orig or run the bike as a good runner. It is a good solid bike that should be looked after and used. There is a lot of people on here that can help you out with your bike i think we all want to keep as many SOHC  Honda's on the road for as long as we can and will help as much as they can. Aim new to this forum like you and have found it helpfull and friendly, i all so have had F2's since 1979 so like Yoshie 823 do know a little about them and how to keep them on the road it was my only transport for years. Enjoy the bike and ride it nice buy.
Paul
PMK:
I knew about the shocks and the exhaust (mainly because they have their name stamped or stickered on them)  ;D
I want to change the fliud in the brakes because I don't know how long it's been in there. Also the brakes feel a little wooden at the front. I used to have a T3 Guzzi and the Brembo's were much nicer.
I'll change to EBC HH pads (the green ones) when the fitted ones wear out. That'll go some way to improve things. The pivots are all free and greased with copaslip too so that's a not a worry. I may also lube the pushrod behind the lever as they can seize up. Also when I took the lever out to silicone the pivot bolt it looked there was battery acid spill (you know that yellow crusty nastiness) in the area.
I know 70's Jap bike brakes were rubbish but I think I've forgotten just how bad they are.
Good job I don't ride as fast as I used to!!  ;D
Navigation
[0] Message Index
[*] Previous page
Go to full version
