Author Topic: Front brake questions?  (Read 4980 times)
« on: October 03, 2021, 01:21:31 PM »
I've started fitting the front brake system together using a new DS master cylinder & all new pipes - so far I've just got the untightened flexi pipes in place with unions & copper washers.
First thing I've noticed is that the brake lever seems larger than the existing clutch lever - also why is there a lug on the master cylinder bracket that prevents it butting up to the switch boss?
I see now why some folk fit the bracket upside down but presumably there is a reason for the spacing lug?
Secondly the mudguard clip position on my new front mudguard is such that the steel brake pipe does not align as it should so at present will not fit. My first thought was to just make up a copper pipe that will bend into position much easier. Might be the mudguard bracket is not quite as it should be?
That got me looking at the clip / gromett situation - I'm minded to push the metal part of the flexi pipe into the gromett so its firmly held by the mudguard clip then make up the new pipe to suit the new position - not bothered about it not being as per factory fit - has anyone tried this?
« Last Edit: October 03, 2021, 01:41:03 PM by Macabethiele (Ted) »
Re: Front brake questions?
« Reply #1 on: October 03, 2021, 05:44:32 PM »
After a monumental struggle after a couple of glasses of red wine I managed to fit the gromett over the metal end of the brake pipe fit the steel brake pipe  bend the mudguard wire bracket and it all fits! Managed to head butt the handlebar end a few times due to mild intoxication but it's done!
Life is good.
« Last Edit: October 03, 2021, 06:18:36 PM by Macabethiele (Ted) »
Online TrickyMicky
« Reply #2 on: October 03, 2021, 06:08:08 PM »
Hi Ted, what you have described here is a carbon copy of my antics earlier this year. My original fitment mudguard was starting to "laminate" across the bracing area between the forks, shame really because I had had it chrome plated to a far superior finish than the original. I had managed to locate and purchase (mortgage?) an original new guard and stays, still in its wrapper with the relevant part Nos.  The quality and placement of the cable/pipe guides left a lot to be desired, much cursing and bending was needed to make it all fit. I re-fitted my original re-chromed stays as the finish was far superior to the 40 year old "new" ones. And, yes, I did bang my head a few times on the end of the 'bars, but in my case the grape juice was used generously as medication.  Good fun ain't it!
« Reply #3 on: October 03, 2021, 06:20:43 PM »
Strange definition of fun but yes fun!
The wine had been good medication but the asprin generated bruise will out me in the morning.
« Last Edit: October 03, 2021, 06:23:56 PM by Macabethiele (Ted) »
Offline smoothoperator
« Reply #4 on: October 03, 2021, 07:00:48 PM »
It's amazing how alcohol fueled engineering often works better than dry. The trick is to get just enough to be confident but not so much that you end up with a botched job. Just like the genius of many song writers although that was often coke or LSD, thinking of Rumours by Fleetwood Mac.
Steve
2017 Triumph Bonneville T100
« Reply #5 on: October 03, 2021, 07:47:41 PM »
Fleetwood Mac with Peter Green now I'm showing my age!
Online TrickyMicky
« Reply #6 on: October 04, 2021, 07:21:27 AM »
Each to their own Ted, my memories are of Stevie Nicks!!!
« Reply #7 on: October 04, 2021, 08:44:28 AM »
I watched a couple of good TV documentaries on Fleetwood Mac from the begginings right  up to present day - not just commentary on old footage, included some recent interviews with the various band members.
« Reply #8 on: October 04, 2021, 09:57:32 AM »
Oh well! 😁
« Reply #9 on: October 04, 2021, 10:02:44 AM »
Part one or two?
« Reply #10 on: October 04, 2021, 02:03:28 PM »
Part one or two?
Both plus an extra one almost as enjoyable as the documentary on the late Ginger Baker.
« Reply #11 on: October 04, 2021, 08:59:20 PM »
Stevie Nicks! :o   Oosh!
 8)
« Reply #12 on: October 04, 2021, 09:29:20 PM »
 8)
My crush is Agnetha Faltskog or even Ginger Spice lol.......................an old man can dream..........no harm done here my gaffer is a blonde?
« Reply #13 on: October 04, 2021, 09:53:58 PM »
Same here so I'm good n all ;D
It was always Stevie Nicks, and that lass that sung lead in Heart n her guitar player, can never remember if they were sisters or something.
Anyway, front brakes............... ;D
« Reply #14 on: October 04, 2021, 10:40:29 PM »
Go back father to the drummer in the Honeys
