Author Topic: Side panel grommets  (Read 16602 times)
Re: Side panel grommets
« Reply #30 on: October 07, 2021, 10:44:42 PM »
I was snorting at Steve ;D ;D ;D
« Reply #31 on: October 07, 2021, 11:05:56 PM »
Spose 6p is expensive,
I mean, you can have the 3p opera
« Reply #32 on: October 09, 2021, 10:55:48 AM »
 ;D
« Reply #33 on: October 09, 2021, 12:45:58 PM »
Alcohol has arrived. Just awaiting wintergreen and I’ll be on it.
« Reply #34 on: October 09, 2021, 03:03:13 PM »
Okay I'll have to ask what is wintergreen when you get it & what does it do with the alcohol are you making some sort of Poteen without a 'still for cold winter nights?
« Reply #35 on: October 09, 2021, 04:31:28 PM »
Yes, that’s it Ted. It’s a potent drink, massage oil or you can treat wood with it (wood….snigger).
Apprantly it’s also a persuasive way of refurbishing your hard rubbers…not yours personally of course.
The double entendres are getting out of hand here :D
« Reply #36 on: October 09, 2021, 07:02:25 PM »
 works well on hard flanges ;D when they go very hard :o
Apparently...........
« Reply #37 on: October 09, 2021, 07:22:32 PM »
 ;D ;D ;D
« Reply #38 on: October 11, 2021, 11:04:31 AM »
Ok, grommet chemistry has commenced  at 11am GMT. First inspection at 2pm….the tension and anticipation.
« Last Edit: December 06, 2022, 09:28:57 PM by Sesman »
« Reply #39 on: October 11, 2021, 12:02:59 PM »
aaaaah, I've got to go out! :-\ ;D
How terribly exciting! fingers crossed for a result 8)
« Reply #40 on: October 11, 2021, 01:42:10 PM »
19mins to first inspection…… ;D
« Reply #41 on: October 11, 2021, 02:01:44 PM »
Give us your initial findings and then again after 24 hours after the soaking.
« Reply #42 on: October 11, 2021, 02:06:02 PM »
By Jove, it’s actually working. I’d say a 20% improvement in pliability.
Still needs more time, so will check in tomorrow.
« Reply #43 on: October 11, 2021, 07:28:50 PM »
Including postage….bargain. Source per chance?
« Reply #44 on: October 12, 2021, 07:54:43 AM »
Ok, runners and riders are in. A complete success. Cheap grommets now pliable like OEM. Will now leave a week to see if pliability changes. Next trick, fit panels and test for security.
