Author Topic: 400 Four - PETROL GRADE CURIOSITY ?  (Read 12741 times)
Offline wildtapholer
Re: 400 Four - PETROL GRADE CURIOSITY ?
« Reply #15 on: October 12, 2021, 02:17:49 PM »
After the carb strip down and lots of problems getting the float levels correct, the petrol I got was regular(or supposed to be) just before we went E5 and E10 route, but I can't help noticing the carb overflow pipes, I keep getting this yellow discharge, from the over flow pipes if I run my fingers over the ends. I haven't took it out for a blast yet after a sympathetic restoration, just a start up in the garage, but it keeps fouling the plugs and running on 2 cylinders, I'm tempted to drain the tank and get some ansel I think it was called, from the lawnmower centre.
Offline 400 Cafe Racer
« Reply #16 on: October 12, 2021, 07:19:15 PM »
I think the main problem is if you leave the bike standing for a length of time
Extended storage leads to the fuel absorbing water as its hydroscopic that then leads to rotted tanks as the water separates from the fuel and then sits in the bottom of the tank
Same happens in the carbs bowls that can rot brass ware etc
Also like it says seals need to be viton but is new to here so most older bikes are not e10 suitable due to older type rubber in use
Also hear that if left even in newer bikes if they are not used often the fuel will damage injectors as you cannot drain these for long term storage unlike good old carbs
I think for newer vehicles obviously the seals are compatible and the main thing is if it’s in regular use the fuel does  not remain for long in the tank and other critical areas of the fuel system
Also not god for my RD35C either
[/quote
« Last Edit: October 12, 2021, 07:21:45 PM by 400 Cafe Racer »
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest     - 1989 CBR600F1 (FK) PC23
              - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project -Now Sold
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
« Reply #17 on: October 12, 2021, 07:22:22 PM »
Thanks for your inputs and responses guys. ;)
Let me throw another variable into my Curiosity question
1. What about petroil mix 2 strokes, do they suffer the corrosion problems or are they inhibited by the presence of Oil in the fuel. ?
2. Our mineral oil requirement for these Hondas can have an effect on the rate of upper cylinder / combustion chamber carbon deposits, as it does in many engines of that era. If the consensus on Q1 is positive, then why not add a small amount of the latest oils to the petrol, like Total INEO ECS that clean the combustion chamber and protect  the catalitic converter.  Clean engine and no rotted tank or Carbs, also acting as an upper cylinder lubricant UCL  !!
Dennis :)
oldchuffer
« Reply #18 on: October 12, 2021, 07:27:36 PM »
I had the same issue as you with my CB750 wildtapholer - i think its Aspen you mean. I drained mine, filled it with Aspen and its been fine since and starts so much easier and its been in for nearly 4 years now.
Offline allankelly1
« Reply #19 on: October 12, 2021, 07:28:00 PM »
E10 is bad for my RD350LC
As it is a pumped system rather than premix in many ways the fuel system is no different to a 4T so the risk of a rot tank fuel line or carbs is still the same as you are just adding oil at the point just before the mixture enters the cylinder
Also I think for premix there is a greater risk of the oil not mixing correctly causing more wear or a potential seizure
Best wishes Al
« Last Edit: October 12, 2021, 07:30:34 PM by allankelly1 »
« Reply #20 on: October 12, 2021, 07:46:47 PM »
Hi Alan,
" Lubricating Effect" I can see where you are coming from with respect to my Q1, since the 2 stroke is entirely dependent on the quality of the mixing to distribute its lubrication.
With reference to my Q2. For 4 stroke use it could possibly be regarded as a form of "Redex", but with modern day benefits ??
Best wishes ;)
« Reply #21 on: October 24, 2021, 08:34:03 AM »
Back in the mid 60's I crewed on a  50ft converted wooden fishing boat for 6 weeks - we sailed from North Wales to Barcelona - although it was a wooden boat it too had a massive sacrificial lump of zinc or magnesium it might have been attached to the Hull.
« Reply #22 on: October 24, 2021, 08:53:37 AM »
I sailed for many years and it was always my job to scrub the bottom to remove barnacles, apply a couple of coats of Copper Bottom antifoul and fit a new sacrificial anode every winter when the yacht was lifted out for winter maintainace. The anode would not last a whole sailing season, so we used to find a suitable place to anchor up as the tide was going out and when the boat was high and dry, go and fit a new anode to the prop and wait for the incoming tide to re float the boat. Easy job if the boat was a bilge keel type as the boat sat upright on the mud but a nightmare on a Fin keel type as the boat used to lay at an angle of 45° until it started to refloat 😁😁😁
« Reply #23 on: October 24, 2021, 09:19:30 AM »
Ooh, sailing.
Got my Clipper Race interview on Tuesday…. ;D
« Reply #24 on: October 24, 2021, 09:21:58 AM »
Ooh, sailing.
Oh wow, you lucky chap.
« Reply #25 on: October 24, 2021, 09:23:20 AM »
Not so sure having seen some of the Southern ocean vids  :-\
« Reply #26 on: October 24, 2021, 09:24:41 AM »
Ah yes, the furious 40's. What a great opportunity for you though.
« Reply #27 on: October 24, 2021, 09:28:25 AM »
Yes, fingers crossed. I expect to return a broken man:physically, mentally and fiscally. Hence getting in the 550 restoration and 500 purchase now.
« Reply #28 on: October 24, 2021, 09:32:18 AM »
Yes, but it will be worth it Phil.
« Reply #29 on: October 24, 2021, 09:32:53 AM »
Sorry for hijacking your thread Ted 😔😔😔😔😔
