Author Topic: Cam box vent pipe  (Read 3077 times)
Offline Popstar
Cam box vent pipe
« on: October 26, 2021, 08:34:46 PM »
After assembly of my carbs from a box of bits I've discovered two vent pipes , the longer one comes out of the vent on the cam box which is very long and would fit on the offset tube appature on the air box, the other pipe has a larger diameter pipe and is sleeved down to a smaller diameter pipe but doesn't appear to have anywhere to live. The bikes is a 71 500k1
« Last Edit: October 26, 2021, 08:38:19 PM by Popstar »
Re: Cam box vent pipe
« Reply #1 on: October 26, 2021, 09:35:38 PM »
71 500 cam vent goes down behind crankcase and open to air, there is also a tube from airbox that does same. Only the 550 recirculate
Offline Popstar
« Reply #2 on: October 27, 2021, 08:55:08 AM »
Ok thanks, I've not come across this before(the one from the air box) I will of course connect it now I know, won't his pipe breath in unfiltered air when you consider it's position?
Offline Seabeowner
« Reply #3 on: October 27, 2021, 09:08:21 AM »
The original pipe from the airbox terminated in a slit so was basically sealed. You were supposed to squeeze the slit to open it to drain any fluids there.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Popstar
« Reply #4 on: October 27, 2021, 09:49:22 AM »
That makes sense.
« Reply #5 on: October 27, 2021, 10:49:14 AM »
Pipe is Plugged with a slit so seals on negative pressure.
