Author Topic: Front Brake Shaft  (Read 2552 times)
Offline Saesneg Shaun
Front Brake Shaft
« on: October 28, 2021, 02:30:53 PM »
Hi,
I'm trying to rectify a squeaky front brake on my K6.
Probably a stupid question but should the piviot shaft be able to move both ends?
The top bit with 2 holes moves fine but the bottom is locked solid?
My Bikes
76' Honda CB750K6
78' Honda GL1000
73' Suzuki GT380K
83' Suzuki GS1100ES
05' Harley Sportster XL1200R
Re: Front Brake Shaft
« Reply #1 on: October 28, 2021, 02:39:12 PM »
Take top and bottom part out and clean up and grease it well. It should swivel top and bottom.
« Last Edit: October 28, 2021, 02:46:47 PM by Nurse Julie »
« Reply #2 on: October 28, 2021, 02:48:25 PM »
Take top and bottom part and clean up and grease it well. It should swivel top and bottom.
Thanks NJ. I'll see if I can get it apart
My Bikes
76' Honda CB750K6
78' Honda GL1000
73' Suzuki GT380K
83' Suzuki GS1100ES
« Reply #3 on: October 28, 2021, 02:49:15 PM »
Put the bottom into a vice to hold, remove top (two hole part) see if you can get the seal out that's underneath that after removing, then spray penetrating oil into the seal gap. Keep doing that for a while then you should be able to rotate the arm on the spindle to free it and get the two apart for cleaning.
« Reply #4 on: October 28, 2021, 02:50:56 PM »
By "bottom" I mean the opposite end of the pivot shaft to the two hole end.
« Reply #5 on: October 28, 2021, 03:37:33 PM »
Thanks, I was just about to put heat on it until I saw you wrote 'seal' lol
My Bikes
76' Honda CB750K6
78' Honda GL1000
73' Suzuki GT380K
83' Suzuki GS1100ES
« Reply #6 on: October 28, 2021, 03:57:22 PM »
The seal is a small O ring, it has been known to drill and tap thr arm for a grease nipple
« Reply #7 on: October 28, 2021, 05:07:23 PM »
Thanks. That shaft hadn't been greased in years by the look of it. I've cleaned it up and re-assembled with copperslip and new O rings for now but tapping a grease nipple is a good idea.
Worryingly the previous owner said it had been given a recent front brake overhaul!
My Bikes
76' Honda CB750K6
78' Honda GL1000
73' Suzuki GT380K
83' Suzuki GS1100ES
« Reply #8 on: October 28, 2021, 07:24:10 PM »
So another small issue. The front mudguard is rubbing on the tyre, mainly the brake line keeper but the muguard is also close.
is my mudguard damaged or have I refitted it wrong?
My Bikes
76' Honda CB750K6
78' Honda GL1000
73' Suzuki GT380K
83' Suzuki GS1100ES
