Author Topic: Speedo dogs  (Read 2835 times)
oldchuffer
Speedo dogs
« on: November 19, 2021, 03:09:19 PM »
This may a stupid question but i'm confused. In my "box of bits" rebuild i do have a front wheel, i need the brake disc and bolts and also a speedo drive, i just cant see how it would work as i cant see any "cut outs" for the speedo dogs to engage into (see pic). How does it work? or have i even got the wrong wheel, the manuals dont make it clear.
Re: Speedo dogs
« Reply #1 on: November 19, 2021, 03:32:11 PM »
That doesn't look like a 500 hub,
It should have 6 holes for the disc.
Re: Speedo dogs
« Reply #2 on: November 19, 2021, 03:41:21 PM »
Thats cos its a 400 hub,
Disc goes one side, speedo drive the other with a chromed plate over that has two raised bits over the drive plate legs and 4 bolts all way through
Re: Speedo dogs
« Reply #3 on: November 19, 2021, 03:49:00 PM »
Oops
Offline allankelly1
Speedo dogs
« Reply #4 on: November 19, 2021, 04:25:51 PM »
Pm sent but here is the picture of the disc that’s was going to the tip as nobody seemed want it
« Last Edit: November 19, 2021, 04:29:14 PM by allankelly1 »
oldchuffer
Re: Speedo dogs
« Reply #5 on: November 19, 2021, 05:33:59 PM »
Pm sent back to you Allan.  I'm still unsure how the speedo drive meshes in with the wheel to get the innards to turn.
Re: Speedo dogs
« Reply #6 on: November 19, 2021, 05:48:33 PM »
It goes the opsite side to the disc, look at a parts fichr
Offline allankelly1
Re: Speedo dogs
« Reply #7 on: November 19, 2021, 05:51:33 PM »
Like this
Re: Speedo dogs
« Reply #8 on: November 19, 2021, 05:56:13 PM »
Parts pic from cmsnl, long time since i did a 400 so forgot that drive plate was held by same 4 bolts and has no "ears"
