Author Topic: Any idea what this is?  (Read 26554 times)
beardylondon
« on: November 21, 2021, 05:51:58 PM »
I am a new owner of a 1976 CB550 and I can't work out what this is for, as circled, any ideas?
Re: Any idea what this is?
« Reply #1 on: November 21, 2021, 06:29:47 PM »
No idea. Never seen one fitted before, doesn't show on the fiché either.
Edit... The footrest itself doesn't look the right shape / type either looking at it more closely 🤔🤔🤔
« Last Edit: November 21, 2021, 06:50:26 PM by Nurse Julie »
« Reply #2 on: November 21, 2021, 07:08:00 PM »
It looks like its a pipe holder or cable holder thats come with the foot peg.  I had a look at the fiche's as well Julie. (I'm a bit bored this evening) and cant see it anywhere either. On the bike that is.
It would make a good battery drain pipe holder if it was turned round to face the other way, maybe its that from another honda?
« Reply #3 on: November 21, 2021, 07:57:07 PM »
If it was on the other footrest it might be a battery vent pipe bracket
« Reply #4 on: November 21, 2021, 10:49:28 PM »
Looks a pretty substantial bracket for a vent pipe holder - could  it have been fitted 180 degrees out with some sort of rubber buffer attached?
beardylondon
« Reply #5 on: November 22, 2021, 01:36:46 PM »
Thanks all, two more photos if this helps?
I'm curious to know if the footrest is incorrect?
« Reply #6 on: November 22, 2021, 01:52:05 PM »
Yes, now I can see the complete foot rest, it is correct. But, the little bracket thing should still not be there. I can't see any purpose for it at all.
beardylondon
« Reply #7 on: November 22, 2021, 04:11:27 PM »
Thanks Julie
« Reply #8 on: November 22, 2021, 04:31:49 PM »
I wonder if the bracket was for a contraption I had once: a switch pulled by the jiffy to prevent starting. For safety. Mine worked OK, but lived short. Where is your bike from? I mean, what 'area code'?
« Reply #9 on: November 22, 2021, 04:41:24 PM »
A side stand switch as per USA so do not ride off with the stand down it has that rubber  thing on the side stand.
beardylondon
« Reply #10 on: November 22, 2021, 05:29:00 PM »
Unfortunately no idea which state it came from.
beardylondon
« Reply #11 on: November 22, 2021, 05:30:54 PM »
The side stand does have the rubber on it, but it obviously doesn’t reach to the that mystery clip.
Offline murdock
« Reply #12 on: November 22, 2021, 05:43:21 PM »
Will it be to hold the center stand?
beardylondon
« Reply #13 on: November 22, 2021, 05:53:42 PM »
The original exhausts are long gone, it’s got a four into one Delkevic.
By the way where are the exhausts from that side? if it's a K2 which your signature says you have it should have 4 into 4 exhausts.
beardylondon
« Reply #14 on: November 22, 2021, 05:54:19 PM »
Nope
