Author Topic: Whine from Speedo or Rev counter  (Read 8376 times)
beardylondon
« on: November 23, 2021, 11:24:11 AM »
Hi All
So I have this noise which I think is coming from the speedo or rev counter.
I recorded it, this is decelerating from 50 to 5mph and riding slowly.
https://voca.ro/14p6IR1mIR2b
I guess the cable needs lubrication, any tips?
Re: Whine from Speedo or Rev counter
« Reply #1 on: November 23, 2021, 02:11:34 PM »
Disconnect each one in turn - when the noise stops you have the source.
Might be a bit dangerous to use a listening stick whilst riding at 50 mph.
« Last Edit: November 23, 2021, 05:49:47 PM by Macabethiele (Ted) »
Offline Tomb
« Reply #2 on: November 23, 2021, 02:18:43 PM »
I had the same, it was the speedo cable, as I pulled up at a junction it stopped, if it was tacho cable it'd keep going as the engine was still turning. I cleaned and lubed up the cable and it was fine again for 12 months. Another thing I found is its cold weather that seems to get the dry cables vibrating, so this time of year.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
beardylondon
« Reply #3 on: November 23, 2021, 06:23:15 PM »
Thanks both, I'll give it some lube.
« Reply #4 on: November 23, 2021, 07:02:20 PM »
Yep, that's the sound my speedo made on Millie the Mongrel 550. I can't remember which way round it is but if it's an OEM cable, don't lube it as the inside swells and causes more issues, or if that applies to the aftermarket cables 🤔🤔🤔🤔 Someone will remind me.... BryanJ 😆😆😆
« Reply #5 on: November 23, 2021, 07:32:31 PM »
Throttle and clutch are lined but speedo and tacho are ok the grease but not too much as it has been known to work its way up into clocks
« Reply #6 on: November 23, 2021, 07:44:28 PM »
Ah yes.... I remember now 😊😊😊😊😊
« Reply #7 on: November 23, 2021, 08:20:53 PM »
100.000 km back I have pulled both tacho- and speedocable, cleaned them with a little kerosene and lubed them just lightly with lithium grease. Never had to do it again so far.
beardylondon
« Reply #8 on: November 23, 2021, 09:32:16 PM »
Thanks all!
Online taysidedragon
« Reply #9 on: November 23, 2021, 11:59:04 PM »
I did have a whine from my speedo instrument and the needle was jumping. Tried a different cable and still did it.
Changed the speedo for a different one and problem sorted.
beardylondon
« Reply #10 on: December 01, 2021, 01:32:56 PM »
Ok it is definitely the speedo, not tachometer. I tried lubing original cable, same. I tried a brand new cable, same. Next step to get mine refurbed, anyone have any recommendations for someone to do it?
« Reply #11 on: December 01, 2021, 01:35:10 PM »
Peter Horton
Kent400 on here.
« Reply #12 on: December 01, 2021, 04:29:34 PM »
if I were you, I'd do one more test: disconnect the cable RH side of the front wheel, to be absolutely sure. There are a lot of possible sources for resonances like mirrors etc.
beardylondon
« Reply #13 on: December 01, 2021, 04:42:56 PM »
I’ve messaged Peter, thanks.
It’s deffo the speedo, did you listen to the audio recording? I lent down while riding slowly and could hear it turning over.
It did it before I bought new mirrors and still does it. Noise completely stops when cable is removed.
« Last Edit: December 01, 2021, 04:50:35 PM by beardylondon »
beardylondon
« Reply #14 on: December 02, 2021, 03:46:01 PM »
Thanks all, I have sent my speedo off to Peter Horton for repair.
