Author Topic: 1975 CB 400 Four - Restoration  (Read 21799 times)
Offline kiki.o
Re: 1975 CB 400 Four - Restoration
« Reply #30 on: January 23, 2022, 02:55:16 PM »
Hi all,
While waiting for some spare parts, the carbs are finished. So it was time to try and to start the engine.
Finally alive after 2016.  8)
https://www.youtube.com/embed/IP7X_nHfnrE
The muffler will be replaced with the marving one, since I cannot find the OEM exhaust for now. This is the one that it came with, and is used just for starting the engine.
Best regards,
Kristijan
« Last Edit: January 23, 2022, 02:57:17 PM by kiki.o »
« Reply #31 on: January 23, 2022, 03:06:37 PM »
Very nice,
Sounds sweet
Offline kiki.o
« Reply #32 on: September 15, 2022, 10:37:30 PM »
Well things are finally coming to an end....
The bike is complete, registered and ridden for a 2000km now.
Here's picture today from Dubrovnik, some 600km away from home.
washed after the trip:
Now it's time to make a first service(oil, filters, lube everything...) and fine tune it.(some jetting problems, some tacho and speedo issues)
Best regards,
Kristijan
« Reply #33 on: September 16, 2022, 06:22:27 AM »
Nice bike. Evokes memories of my 1979 one.
« Reply #34 on: September 16, 2022, 06:59:02 AM »
Why is the fuel line routed like that?
« Reply #35 on: September 16, 2022, 10:55:38 AM »
Slightly overlong pipe needs the heat protecting coil spring on it.
Offline kiki.o
« Reply #36 on: September 16, 2022, 11:00:35 AM »
I don't know, it seems like the most logical route?
what would be the correct route?
Ted, you're right, the spring is missing, I'm still searching for it. I need to leave something for the winter service  ;D
« Reply #37 on: September 16, 2022, 01:52:16 PM »
I think your route is close but due to to the excess length of the pipe it's a tad higher on the carb top. If you fit the  spring in the future it will reveal the required length.
Offline kiki.o
« Reply #38 on: September 17, 2022, 11:52:30 PM »
Yeah, I'll try to get the spring.
Thanks on the input.  ;)
