SOHC.co.uk Forums > CB750
750 Gasket set.
<< < (3/3)
royhall:
Phil. My GS shims are 29.5mm and I think Z1 shims are 29mm. So it looks like they are GS items. A guy in my local VMCC has a GS550 and needs a valve tool, so can we take them off you. Will send a PM with my address. Let me know what we owe you. Cheers Roy.
royhall:
Just to bump it up again. Any suggestions on the best gasket set for a 750K5.
Sent from my Pixel 6 using Tapatalk
Nurse Julie:
--- Quote from: royhall on December 19, 2021, 06:14:05 PM ---Just to bump it up again. Any suggestions on the best gasket set for a 750K5.
--- End quote ---
OEM, Vesrah, NE Brand, in that order. We have used all types on customers engines, depending on what they request, with no issues at all. If the NE brand gaskets are too large, ie, stick out a bit when fitted, just trim the excess of if you wish, although on our own bikes that we have used them on, Trigger doesn't even shave them down, he just leaves them as they are. You will need to upgrade all the O rings on any of the kits as the gaskets are not the same thickness as Original OEM Honda ones.
royhall:
Thanks Julie I will have a hunt for a Vesrah set.
philward:
Check DS Roy - as they listed a cheaper and a dearer set when I bought a set for my 500 - the dearer set was Vesrah. Would think they do the same for the 750?
Navigation
[0] Message Index
[*] Previous page
Go to full version
