Author Topic: Honda color coded wires?  (Read 12860 times)
Offline ST1100
« on: January 08, 2022, 06:08:48 PM »
hmm...
my previous supplier (http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php) for re/building wiring harness seems to have gone out of business...
Where to get cables with the proper color-coding now?
TIA
STOC #637
Re: Honda color coded wires?
« Reply #1 on: January 08, 2022, 06:23:23 PM »
https://www.vehiclewiringproducts.co.uk/
I'm sure someone will suggest a company near you though.
« Reply #2 on: January 08, 2022, 06:37:17 PM »
Anyone know where I can get thin-walled 1mm² stranded conductor, PVC in Black with White tracer in relatively short lengths (i.e I don't want to buy a full reel).
UPDATE .. looks like Julies link does it /m
« Last Edit: January 08, 2022, 06:46:38 PM by AshimotoK0 »
« Reply #3 on: January 08, 2022, 06:43:43 PM »
Honda Al probably.
Offline ST1100
« Reply #4 on: January 09, 2022, 10:03:51 AM »
Damn, there it is...
Thanx a lot Julie!
And no, sources for specific cabling and connectors are pretty limited; best sources appear in UK and the US...
Kept digging and found this: http://www.polevolt.co.uk/acatalog/Thinwall_cable_cut_to_length.html
offering color coded cabling in 1mm² and upwards, nice
« Last Edit: January 09, 2022, 10:09:44 AM by ST1100 »
STOC #637
Offline Moorey
« Reply #5 on: January 09, 2022, 10:09:31 AM »
   Is this any good for you. https://www.12voltplanet.co.uk/P00646.html?gclid=EAIaIQobChMI1ojo5bSk9QIVku7tCh0VuAysEAQYASABEgJlVfD_BwE
Offline kent400
« Reply #6 on: January 09, 2022, 10:42:36 AM »
Further to Steve's post Honda AL is Alan Lowe his email is alan@alanlowe.co.uk
He makes wiring looms for quite a large range of bikes and gauge wiring looms for ND gauges. Often the rubber covering of the bulb holders are stuck in the gauge bulb apertures and disintegrate upon removal. The rubber covers are available from David Silver but at about £7 a piece plus the VAT and post.
A problem may also exist is that the bulb holders are corroded. Alan's ND looms come with new bulb holders and the wiring so a better option than just replacing the rubber covers. Saves the trouble of unsoldering/soldering the bulb holder to fit new rubber covers.
Good quality and Alan is a very pleasant to deal with.
Just to clarify these gauge looms are for all CB750 fours, CB550 and CB500 fours that have ND gauges fitted. Kawasaki Z650, 900 & Suzuki GT750 also had ND gauges.
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #7 on: January 09, 2022, 06:15:41 PM »
Thanks for the mention. The lamp holder rubbers that I stock as image, will only fit the larger ND gauges with 14mm lamp sockets... CB750, GT750, Laverda Jota clocks. Most of the smaller Honda gauges have 12mm lamp sockets.
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
« Reply #8 on: January 10, 2022, 02:52:58 AM »
Are you saying the Nippon Seiki gauges use a different size bulb holder Al?
« Last Edit: January 14, 2022, 07:05:58 AM by Oddjob »
« Reply #9 on: January 10, 2022, 07:49:28 AM »
Both links are great .. thanks!
I measured Honda cable and its around 2.3 to 2.4 mm overall dia with 30 bare copper strands of 0.2mm wire which equates to about 1mm² conductor size
However, the thin-wall cables both companies sell at 1mm² conductor size  is only around 2mm but their 1.5mm² cable has 0.3mm strands but the correct overall OD for Honda's generally (i.e coil wires, indicators etc)
Has anyone  used their  cables and which version did you choose .. I guess for original look 1.5 mm² will be the best and higher current rating but probably a bit stiffer than the original Sumitomo stuff.
Offline Moorey
« Reply #10 on: January 10, 2022, 10:10:04 AM »
  Ash the 12v planet link i gave gives the wire spec as No./size of conductors: 32/0.20mm so should be good for you.
« Reply #11 on: January 10, 2022, 10:17:02 AM »
cheers ..its a bit down on OD though 2.0mm as opposed to 2.4 mm on Honda stuff. Just wondered if people opt for the 1.5 mm² stuff as it's the correct OD
« Reply #12 on: January 10, 2022, 11:13:04 AM »
Are you saying the Nippon Denso gauges use a different size bulb holder Al?
Most of the gauges/consoles that I have measured have 12mm lamp holder sockets. If there are other gauges that have 14mm sockets, please let me know.
Current bikes:-
Offline Moorey
« Reply #13 on: January 10, 2022, 11:15:35 AM »
   For me it would depend purely on the load it was going to carry.
« Reply #14 on: January 10, 2022, 12:54:57 PM »
Just measured an indicator wire and just slightly above 2 mm so I will go with the 1.0mm² thin wall
