Author Topic: Electronic ignition  (Read 95912 times)
Re: Electronic ignition
« Reply #120 on: January 18, 2022, 04:18:17 PM »
The best instructive vids about our SOHC Fours are made by Marco, a member of the German forum. With his soft, modest voice he demonstrates restaurations in detail, explains all his findings, etc. Although it's in German, I like to honour him and present a link to his tutorial on the CB350F ignition system which is ofcourse very similar to ours. Although the video is worth watching as a whole, I'd like to point at the section where he summarizes all data on paper: 26:52 - 35:26 and - more in particular - where it is about Sättigung (saturation) in 28:41 - 29:12. New to me was, that there's a standard formula for inductance and that at max rpm in Honda's stock set up, our coils become saturated for only two thirds. Actually partial saturation begins at around 6500 rpm. TEC has ofcourse dimensioned the coils thus, that they are adequate.
For convenience I've made a copy in translation, which you find below. If you need more translation, feel free to ask. If you can shoot holes in his explanation, you're invited ofcourse. He is a friendly person and always open to criticism.
https://www.youtube.com/watch?v=HBJY8705gdc&t=1747s
HONDA CB350F  IGNITION                          Specifications and Settings
         COILS                                                            TEC FL703-12V
  Primary resistance                                                     ~ 4,5Ω
  Secundary resistance                                                 ~ 14,7kΩ
  Turns primary                                                               420
  Turns secundary                                                         13.000
  Voltage secundary                                         @ 10001/~14kV  @10.0001/~11kV
  Inductance        ~ 14mH
  Saturation (see 28:41-29:12 for explanation)   Ï„  = L/Rp = 3,1ms (63,2%)   Ï„  x 3 = 9,3ms
  Charge time @   1.000 rpm and 55% Dwell*     1 revolution = 0,06s         >        33ms
  Charge time @ 10.000rpm and 55% Dwell*      1 revolution = 0,006s       >          3,3ms
       CONDENSERS
  Capacity                  0,22 μF +/- 10%
courtesy Gruzzel
* Actually it is 55% Duty Cycle which equals 49,5o Dwell (4 cyl scale) which is a tad narrower than a 0,3 mm gap. Personally I'd chose a somewhat wider opening as the gap tends to narrow over time (Deltarider).
« Last Edit: January 19, 2022, 08:28:13 AM by deltarider »
Offline allankelly1
Electronic ignition
« Reply #121 on: January 18, 2022, 04:54:53 PM »
Hi all
Been following this thread with some real interest
Like it had been said the original Honda design is up to the task and I am not making any claims I understand any of the electronic stuff, but for me personally if you are going to add any electronic control to a ignition system it make more sense (for me) just to replace the lot rather than have a modified /hybrid system
Modern Electronic ignition systems are well proven and with a system such a Boyer Brandsen you remove all the mechanical switches and the mechanical ignition advance and simplify everything, and for me it’s knowing that the complete ignition system is as good as new (if it needs replacing) even if it is a bit of an expense at the time.
(The full system included magnetic pick up CDI and two micro coils was only £237 which I felt was good value for a complete electronic ignition system when you look at how much we spend on our toys)
This is not a criticism of this thread or anybody here as I can see there are some real electronic gurus and wish I did understand it but I am more of a mechanical engineer and is just a personal point of view
Best wishes to you all Al
« Last Edit: January 18, 2022, 05:22:22 PM by allankelly1 »
Online Sesman
« Reply #122 on: January 18, 2022, 05:24:49 PM »
Totally agree oddjob. But of course if your points and condensers are near to end of life then the Velleman self build makes good sense when considering the cost of good quality points and condensers. Unless somebody can supply me with a source at a reasonable cost….reasonable to me that is.
Does the Hondaman kit utilise the original capacitors? If so then the buyer could be in for some unforeseen additional costs if his condensers are fooled.
I really don’t know. The Ashmac solution (mainly Ash) is just an inexpensive experiment rather than a contender.
« Reply #123 on: January 18, 2022, 05:45:18 PM »
"Does the Hondaman kit utilise the original capacitors? If so then the buyer could be in for some unforeseen additional costs if his condensers are fooled."
As I understand it, no his system doesn't use them. He leaves them in place but disconnected such that IF his electronics were to fail, then you can hook them back in circuit at roadside in reverting to straight points ignition to not leave you stranded.
Essentially the switching transistor takes all of the load itself with no need of condenser to mitigate. The "fault" side of the points that the condensers are there to control doesn't go away (as are most things in physics) it just comes out as heat from that transistor which has to be adequately dispersed to avoid failure of that component.  Two different sides of a square in carrying out the same task effectively.
« Reply #124 on: January 19, 2022, 08:39:13 AM »
I could have left out my condensers. They are not needed for the power transistor, because it switches full yes or full no. Without the condensers, the benefit would be an even steeper rise time, which is fine. However, breakerpoints are not as perfect in switching as transistors, so there is a chance, if the points are 'hesitating', so to speak, in their opening and closing, they may cause the power transistor to switch multiple times. For the transistor itself that would be no problem. I could experiment with it to see if this really does happen. My electronic tach/dwell meter would tell me by showing funny readings. But I am satisfied with the rise time as it is now, so I kept the condensers. Whether these are the Honda ones or the ones that came with the kit, is the same.
Also, IIRC Hondaman at first had condensers built in, like in my module, then left them out, then later, after some customers had experienced irregularities, advised to use condensers again, but now the OEM ones that are at the base plate. Smart choice as this makes returning to OEM, in case of failure, even easier. Also this makes his modules cheaper to make, condensers being the second component in price after the power transistor.
Those of you that have studied the data in reply #170, will now understand that where the stock ignition cannot saturate the coils completely in the higher rpms, my module can, thanks to that shorter rise time it provides. As predicted by Bosch and Steinbuch, the gain is in the low and in the high rpms.
« Reply #125 on: January 19, 2022, 01:18:41 PM »
Not 100% sure but I seem to recall Mark saying the condensers were left in circuit so that reverting to the points was just a matter of disconnecting the module and restoring the blue/yellow connectors to the original positions. Might be wrong though. If not, then your going to need a toolkit to revert by the roadside.
« Reply #126 on: January 19, 2022, 02:29:45 PM »
I am not sure, I can share your view. First of all, the 'heat' at the back of the power transistor is hardly there. I mean, I can practically hold my finger there. The condenser is there to dampen possible 'hesitation' of the breakerpoints in their opening and closing and so prevent the transistors interpreting all of these 'hesitations' as switch moments. it would result in multiple switching by the power transistor, which in its turn would produce erratic sparking, that is: if there would be anything left to spark from...
The condenser is there to make sure the transistors receive one - and only one - clear signal.
« Last Edit: January 19, 2022, 08:13:26 PM by deltarider »
« Reply #127 on: January 19, 2022, 03:46:35 PM »
All of this is a very interesting project, but aren't you just reinventing the wheel. There are many systems already out there that do this job reliably and only need 30 minutes to fit. I have had EI on every bike I have owned for years and never had a breakdown. On some of the bikes, EI was fitted after the points system left me stranded. Don't shoot me down just saying.
« Reply #128 on: January 19, 2022, 08:26:23 PM »
Back then, I had no choice than to make my own. All products that I had seen (Piranha, etc) were not to my liking. For my travels I wanted something robust with a guaranteed simple back up, other than eventually having to apply for a new black box in farawaygistan and then possibly having to wait days for the thing to arrive. In particular I didn't like the positioning of the electronics. Mine are high and dry - I can cross a stream with it - and they see no higher temperature than ambient. They are shielded against vibrations and moisture. And there's the joy of making the thing yourself ofcourse. :D
« Reply #129 on: January 19, 2022, 08:27:03 PM »
 ;D ;D ;D ;D ;D ;D ;D ;D
Online Sesman
« Reply #130 on: January 19, 2022, 08:42:19 PM »
 ;D ;D ;D ;D
« Reply #131 on: January 19, 2022, 11:17:17 PM »
 ;D ;D
« Reply #132 on: January 20, 2022, 07:03:48 AM »
Okay I will zip it.
Sent from my Pixel 6 using Tapatalk
« Reply #133 on: January 21, 2022, 09:12:32 AM »
"As said, I've abandoned the heatfins, which are an exaggeration IMO and have used the bottom and the lid of the alu box to let the power transistors dissipate their heat."
From your post #100 there will always be a byproduct, however the size of it manifests. It may be less or more at any one point in a system (denoting efficiency of that system relative to another) but it won't go away.
« Reply #134 on: January 21, 2022, 09:20:07 AM »
Curios about the logic here. Starting with a Honda system that was effectively peerless when contemporary,  placing another whole system to be more reliable?  with the original as backup,  appears inverted in straight mechanical logic. Backup contingency would surely be two sets of points and two condenser stored on the bike perhaps (maybe in the headlight shell to be always available) and you'd never be stranded such that requirements of outside assistance is necessary.
I get that the electronic systems can reduce the duty load of the original points, but many of these in period additions where constructed and sold on attributes that will definitely improve a number of elements on car distributor systems that never existed in the Honda 4 cylinder ignition systems in the first place.
