SOHC.co.uk Forums > CB350/400
Oil filter housing bolt.
Bradders:
Thanks Bryanj. I shall do the same then, maybe it won’t need a blowtorch to get it off next time then.
400 Cafe Racer:
--- Quote from: Bradders on January 28, 2022, 04:43:39 PM ---Do you think it’s ok to torque it up to the level the manual says, or is that too tight?
--- End quote ---
Also - think canister filters doing the same job - only hand tight with no tools, as Bryan says, just nipped tight is all it takes if the "O" rings are all good.
Bradders:
Thank you all for your replies. I think it must of got done up too tight last time as it was a sod to get off.
Bryanj:
One reaso why Honda had a piddly 12mm hex on the bolt
Seabeowner:
And never use a 12pt ring spanner on the 12mm head. Six sided socket only.
Navigation
[0] Message Index
[*] Previous page
Go to full version
