Author Topic: Final drive sprocket off when taking out engine?  (Read 5781 times)
Offline alexdecker
« on: January 30, 2022, 01:28:03 PM »
Hey all
The manual says to remove the final drive sprocket and the chain when removing the engine. Can I just remove the chain? Can’t for the life of me get those nuts loose for the final drive. Any tips appreciated!
- Alex
Re: Final drive sprocket off when taking out engine?
« Reply #1 on: January 30, 2022, 03:20:44 PM »
You can leave it on but at some point those bolts will have to come out. Plus there is a risk you'll cut yourself handling the engine out of the frame on the sprocket if your hands slip. The bolts go into the sprocket so if they snap it's not a big deal, you could try a little heat to see if that loosens them up. Just be careful you don't melt the seal behind it unless your replacing that of course.
« Reply #2 on: January 30, 2022, 04:46:46 PM »
Should have undone them whilst chain was on using brake to stop wheel
« Reply #3 on: January 30, 2022, 09:17:59 PM »
A good cordless impact driver might shift them.
« Reply #4 on: January 30, 2022, 09:35:47 PM »
If you have got the engine out already (not sure if you were making enquiry prior to taking it out), you could use the chain as a wrench on the sprocket with a large screw driver through links to hold it while impacting bolts
Offline alexdecker
« Reply #5 on: January 31, 2022, 03:13:32 PM »
I got it off, not without a decent amount of sweating and swearing. My god, hope this is not a taste to come.
I found this on the floor when I was done with dissassembling the engine from the frame. Can't think of anywhere on the bike this goes. Is it a left-over of some other project in the garage, or is this a CB550 thing?
« Reply #6 on: January 31, 2022, 04:11:50 PM »
  is it metal ?
  at first glance it looks like the press top of an aerosal can.
Offline murdock
« Reply #7 on: January 31, 2022, 04:20:35 PM »
looks like a speedometer or tachometer nut
« Reply #8 on: January 31, 2022, 05:18:42 PM »
Looks identical to the internal cap on the speedo drive, someone looks to have drilled it to pull it out when it just knocks out from the drive side.
