SOHC.co.uk Forums > CB350/400
Spark plug threads
Trigger:
You need a high temp retainer. Something like loctite 638 10ml.. Can be had on ebay cheap because it is out date but, it doesn't go off until under pressure. I still use thread lock and retainer that i have had in liter bottles since the 90's
oldchuffer:
Thanks for the advice, will get some sorted.
oldchuffer:
Update: For the stripped thread i used a time-sert, (using a 12.3mm bit). I also used Loctite 638 on the outside of the time-sert. And it worked a treat. Thanks so much everyone for the advice, and thanks Trigger for the tip about 638.
McCabe-Thiele (Ted):
--- Quote from: oldchuffer on March 24, 2022, 08:31:13 PM ---Update: For the stripped thread i used a time-sert, (using a 12.3mm bit). I also used Loctite 638 on the outside of the time-sert. And it worked a treat. Thanks so much everyone for the advice, and thanks Trigger for the tip about 638.
--- End quote ---
I would replace the plug washers if you re-use the plugs - it should minimise any chance however remote of the insert coming out attached to the plug.
Maybe these inserts have improved over the decades and you will be okay, I did a service on a friends Carlton and a Helicoil came out with the plug!
oldchuffer:
Yes i have new plugs Ted. I'm happy everything looks ok but of course I'll have to wait til i start it to see for sure. The head is back on now and the camshaft in.
Navigation
[0] Message Index
[*] Previous page
Go to full version
