CB350/400
Checking the valve timing on a 400.
Topic: Checking the valve timing on a 400. (Read 12280 times)
McCabe-Thiele (Ted)
April 03, 2022, 04:57:39 PM »
Whilst working on my timing this afternoon I briefly got confused with where TDC is I started to use the 1-4 double mark on the right instead of the "T" on the far left.
That got me thinking if I could have made a similar mistake when I fitted the camshaft in place - I probably did not but I am concerned enough to need to double check.
Is it possible to check the valve timing without having to remove the top cover?
Link to my full restoration
Re: Checking the valve timing on a 400.
April 03, 2022, 05:30:20 PM »
Yes Ted, remove the tappet caps from the cylinder by the timing marks and rock the engine backwards and forwards over the T mark whilst observing the rocker arms, on one tdc they will not move(compression stroke) on the other (one turn of crank=1/2 turn of cam) the rockers will each move up and down an equal amount ( exhaust stroke tdc)
Hope that makrs sense
McCabe-Thiele (Ted)
April 03, 2022, 05:57:58 PM »
Perfectly thanks Bryan.
McCabe-Thiele (Ted)
April 05, 2022, 02:07:46 PM »
Well despite feeling crap I decided to check if my valve timing is as it should be.
Firsty with number 1 cylinder on Tdc I moved the engine forwards and backwards over the T mark neither moved. I then rotated the engine a half turn (2-3 T mark) I only observed movement on number 1 exhuast - number one inlet did not move.
Looks like I've messed up Bryan so I will need to get it sorted groan........it was going so well.
Last Edit: April 05, 2022, 02:15:06 PM by McCabe-Thiele (Ted)
April 05, 2022, 03:19:44 PM »
NO you dont check on 2/3 you both checks on 1/4 one at tdc comp one at tdc exhaust
You should move the CRANK one full turn which moves the CAM 1/2 turn
McCabe-Thiele (Ted)
April 05, 2022, 04:49:11 PM »
Okay (again) the first thing I checked was with No:1 at Tdc on compression - both valves were shut with the right tapett clearance - rocking either side of "T" no movement at No1 rocker.
Tomorrow I rotate the engine one complete turn to look if both No:1 arms move at the same time one up one down when repeating the rocking at "T".
McCabe-Thiele (Ted)
April 06, 2022, 07:43:19 AM »
All work stopped - last night we both tested positive for Covid. My temp is 102F.
K2-K6
April 06, 2022, 08:09:42 AM »
Oh no ! Hopefully you'll get these symptoms and nothing more serious as it seems to be running through this iteration of it.
Best wishes for you and Mrs Ted.
Nurse Julie
April 06, 2022, 08:53:15 AM »
I hope you both feel better soon Ted.
Rozabikes Tim
April 06, 2022, 09:03:33 AM »
Take care both of you.
smoothoperator
SOHC Expert
Reply #10 on:
April 06, 2022, 09:45:44 AM »
Put your feet up Ted and take it easy, the bike will wait for you. Get well soon.
Steve
2017 Triumph Bonneville T100
Laverdaroo
Reply #11 on:
April 06, 2022, 10:35:53 AM »
Go steady, and Mrs Ted
Get well soon mate.
oldchuffer
Reply #12 on:
April 06, 2022, 11:38:21 AM »
Take it easy Ted, hope you both feel better soon.
Steve P
Johnny4428
Reply #13 on:
April 06, 2022, 12:04:33 PM »
Yes indeed! Rest, feet up, hope your symptoms are not too bad. Get well soon.
taysidedragon
Reply #14 on:
April 06, 2022, 12:09:06 PM »
Get well soon Ted, and the boss! 🤒🙂
CB350/400
