Author Topic: Swingarm play?  (Read 11269 times)
Offline paulbaker1954
Swingarm play?
« on: April 15, 2022, 07:56:00 AM »
Just noticed that if I push rear wheel there is a small amount of play movement in the swingarm.
How much play should there be (I assume the answe is none)?
Is it a difficult job to fix and what parts do I need to buy?
Thanks all
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Swingarm play?
« Reply #1 on: April 15, 2022, 09:28:20 AM »
If it is a tiny amount, pump it full of grease, it could take up the slack,
If it is a lot of movement,
Buy some new bushes from Nurse Julie,
It's not difficult, to replace them,
The trickiest is to get the old ones out,
I chickened out,I got a local engineer too remove and replace for about a tenner,
Re: Swingarm play?
« Reply #2 on: April 15, 2022, 09:39:05 AM »
Yes, I thought the same as John, a trip to nurse julie's parts surgery for the new bronze bushes should see you right as rain.  ;D
Re: Swingarm play?
« Reply #3 on: April 15, 2022, 11:47:36 AM »
The collar wears as much ,if not more, than the bushes and is still available from Honda but expensive
Re: Swingarm play?
« Reply #4 on: April 15, 2022, 02:15:29 PM »
Paul I recently bought the needle roller conversion kit for the 500/550. It's made by Tourmax, a Japanese company, it's one of the best aftermarket mods I've ever seen, the attention to detail is superb.
It cost £120 ish, depending where you buy, ok so that sounds a lot BUT you get a new collar and this one is hard chromed and shouldn't wear like the OE one, the needle bearings look really good and there are special washers for the end gap which rotate internally. Factor in the cost of a new collar, £60 or so, new bushes, another £25 and then also factor in how long these are likely to last, the greasing system for the 500 isn't the best IMO, it goes through the spindle and out through 2 small holes, the problem is the grease exists inside the collar and you really want it between the collar and the bush which is where it always wears, there are 2 small holes in the collar but if these block with old grease very little gets where it's needed and hence the collar ends up being worn away. To me it's a maze inside there that the grease has to negotiate in order to get to where it's needed, you tend to stop pushing grease in when you see it exit between the end of the arm and the frame but there is absolutely no guarantee it's got to where it's needed, it will always find the easiest way out.
The only problem with the new needle conversion kit is that the existing greasing system on the 500 (not the 550) isn't suited for it as there are no holes in the new collar so you need to add a new grease nipple onto the swinging arm tube, just done mine and it was very easy to do.
Your choice, £120 and virtually forget it except for greasing or £85 (not including new felt washers or the 550 metal end caps) or so for the existing system which can last only a few years unless your lucky and the greasing system works as it should.
Offline Kelly E
  • Geriatric Hooligan
Re: Swingarm play?
« Reply #5 on: April 15, 2022, 05:56:41 PM »
I have done the Tourmax needle bearing swingarm conversion on my 74' CB 550K0. Between the needle bearings and the radial needle bearing end caps swingarm motion is so smooth now, there's absolutely no drag or play felt at all. Oddjob's grease fitting idea is a good one, I'll be doing it soon.
The Rust Brothers Garage Collection
1974 Honda CB550 K0
1975 Honda CB400F Super Sport
1979 Honda CB750F Super Sport
1980 Suzuki GS1100E
1982 Honda CB900F Super Sport
1983 Honda CB1100F
1984 Honda VF700S Sabre
1984 Honda VF1000F Interceptor
1990 Moto Guzzi 1000 Le Mans
1994 Kawasaki Concours ZG1000
2006 Harley Davidson Fat Boy
Re: Swingarm play?
« Reply #6 on: April 15, 2022, 09:00:31 PM »
The 550K0 may already be done Kelly, if you have a grease nipple under the swinging arm it's ok. If you have one either end of the swinging arm spindle you'll need to do it.
Offline Kelly E
Re: Swingarm play?
« Reply #7 on: April 16, 2022, 01:37:15 AM »
Nope, it's a early 74' 550 #449 and it came with the grease fittings on the end of the bolt.
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Re: Swingarm play?
« Reply #8 on: April 16, 2022, 08:02:10 AM »
There are a couple of problems with the needle roller system. First is a needle bearing was designed to spin and not to just move back and forth. I have taken lots of these apart with notching problems and found the the needles in the bearings have gone flat, no problem you may think just get some new bearings. But, the bearings are a weird size and are under licence and are only available in the kit  :o  I have a number of shafts in good condition ( which never seem to wear ) from the kits but, can not get the bearings.
The second problem is the end caps are a two part turn system that need to be packed with grease. The road grit gets in them so, it is best to remove them once a year , clean them out and repack with grease again  ;)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Swingarm play?
« Reply #9 on: April 16, 2022, 11:46:44 AM »
An interesting observation Trig wrt that the bearing doesn’t actually spin, but rather ‘rocks’.
That said, I note my MotoGuzzi rear suspension (mono shock) uses needle rollers, which barring insufficient factory grease seem to be reliable enough once ‘properly’ lubed with a water resistant grease. (the unit is directly in line with the rear wheel, not good)
The bike has a couple of Achilles Heels, but this isn’t one of them. My guess is it boils down to quality of maintenance.
As an aside, would the ‘rock’ logic not also apply to steering head (ball) bearings if it were correct?
« Last Edit: April 16, 2022, 11:55:13 AM by Lobo »
Re: Swingarm play?
« Reply #10 on: April 16, 2022, 12:36:39 PM »
Yes it does, which is why the original cup and cone with loose balls get notchy AND SO DO TAPER ROLLERS.
In a wheel bearing situation tapers will last well over 100,000 miles but i have seen "notchy" taper head bearings at less than 20,000 when i was testing.
Re: Swingarm play?
« Reply #11 on: April 16, 2022, 01:08:32 PM »
Quite a few of the later Hondas are using needle rollers now as well. My CB1300 has roller bearings at one end, 2 of them, and needle roller at the other. So long as they are greased they seem to last ok, however I got an advisory on play on it's first MOT, Honda seem to have forgotten what grease looks like.
I've actually found 4 new needle rollers for the kit, for the future, just in case it ever needs them.
Re: Swingarm play?
« Reply #12 on: April 16, 2022, 03:53:23 PM »
I don't feel that needle rollers have any problem at all with handling the loads encountered here, specific materials may have caused a problem (that's material integrity, specification though ) but the concept is sound and doesn't need to rotate to keep it alive.
There's difference in bearing design for roller arrangement, with crowded, no cage favouring highest load and lowest speed of movement. Caged, with seperated rollers usually in high axle speed demands.
Lubricant too, these slow and low angular applications need ordinarily molybdenum disulfide grease to pair with their movement characteristics if load is extreme. Driveline coupling does exactly this, with CV joint using balls in grooves with very little movement even during turning. Also propshaft UJ (universal joints) that use crowded needle type with very very low roll movements, again with molybdenum disulfide grease in high torque applications.  These are almost identical in load and lubrication to the swingarm application.
Wheel bearings (ball race or taper roller) don't use molly grease as it builds heat in the bearings at continuous and raised speed installation, they ordinarily use lithium base grease that runs thin at point of contact to avoid this, reducing systemic friction too in comparison to molly type.
The needle type should have no problems if specified and lubricated properly.  They of course have no thrust and need something to prevent sideways movement,  but so do plain bushes.
Re: Swingarm play?
« Reply #13 on: April 16, 2022, 09:12:32 PM »
So are you suggesting using MolyD grease on the swinging arm if using needle rollers Nigel?
Funnily enough, just bought 2 new grease guns, ones for cartridge LM grease and the other I was thinking of filling with MolyD.
Re: Swingarm play?
« Reply #14 on: April 17, 2022, 08:45:56 AM »
Yes Ken, it's the right application for that,  the headstock too.
There's absolutely no need for any speed (linear speed of bearings in that usage) with the MollyD being ideal for that movement and load handling environment.
On that vein,  the original plastic type should benefit from using a PG75  grease for the best longevity with material usege originally.
