Carb 069A sync....
Topic: Carb 069A sync.... (Read 7065 times)
Andy1488
Newbie
Nearly at the gym.
Carb 069A sync....
April 28, 2022, 10:50:39 AM »
Ok people, this has been asked multiple times, and I already know the answer...anyway...
Block number is CB550E.. carbs fitted are 069A's.. sync usually carried out by attaching gauges to inlet headers, via four screws...correct so far.... soooo, where are my screws...I have been over the inlet headers with a fine tooth pick and there are none whatsoever. Going off the history and the P/O, removing the choke butterflies, I can only presume that the inlets have also been swapped...I have no idea why... so my real question is are the carbs or the inlets wrong..?
I am fully aware of how to bench sync these carbs, but I'm a bit of a perfectionist when it comes to the carbs, as I like to use gauges for a visibly accurate setup.. so how much messing is it going to be buying carbs with the vacuum ports fitted, rejetting etc or easier and cheaper to buy the correct inlet manifolds and swap them out...just answered my own question really. Whoever did these carb mods was either bored, an idiot or a complete fckwit...or all 3.
mickwinf
Re: Carb 069A sync....
April 28, 2022, 11:42:02 AM »
It sounds like you have the inlets from the later 550 k3, they had no take off for the vacuum pipes as the screw was on the carb itself (they were pd 46 carbs, horrible things). easiest way is buy some of the correct inlets, 500 four or 550 f/k1 k2, someone on here will probably have some for sale.
Oddjob
April 28, 2022, 02:39:05 PM »
Spot on Mick. I did have some but sold them a few years ago. I should have loads of them around considering how many engines I broke but can't seem to find anymore.
Andy1488
Newbie
Nearly at the gym.
April 28, 2022, 03:01:33 PM »
Turning into a money pit....🤣
Oddjob
April 28, 2022, 03:14:49 PM »
Makes you wonder if the engine was a K3 to start with.
Thankfully they went with the 069 carbs and not the PD ones off the K3, that's a HUGE plus for you as the PD carbs are just awful.
Andy1488
Newbie
Nearly at the gym.
April 28, 2022, 04:16:31 PM »
I honestly have no idea..I know certain things are customised etc, when building a chop, but to remove butterflies and not being able to sync it is a bit weird to me.. like I said, bench syncing isn't a problem, I just prefere to be more accurate on the carb side..
Sesman
April 28, 2022, 05:54:13 PM »
Er, the carb sync screws are on the throttle bell crank, not the and carb inlet?
Oddjob
April 28, 2022, 06:00:13 PM »
He means the adapter screw holes Phil. Those are on the inlet manifolds.
Sesman
April 28, 2022, 06:02:28 PM »
Rrrrr, the vacuum connection points….I didn’t realise some of the SOHC didn’t have them. Another school day.
Andy1488
Newbie
Nearly at the gym.
April 28, 2022, 08:50:52 PM »
Sorry for not being more descriptive..I meant the vacuum connection points on the manifold...I could always tap my own, and fit a permanent port using a m5 mig weld end and hoses caped off....just a thought.
murdock
SOHC Member
Reply #10 on:
April 28, 2022, 09:19:11 PM »
could you make the holes right? and sync from there, or you could use one of those vacuum gauges.
put more photos of that great chopper
podrias hacer los agujeros tu verdad ? y sincronizar desde alli ?, o podrias usar uno de esos medidores de vacio .
pon mas fotos de esa chopper estupenda
Andy1488
Newbie
Nearly at the gym.
Reply #11 on:
April 28, 2022, 09:41:57 PM »
Drilling and tapping the holes wouldn't be a problem.. 4, 5 or even 6mm would be fine.. using a brass mig collar, at m4, m5 or m6 would work, as I've used this method before on the yamaha fzr1000 exups... the small brass ends fit perfectly in tight places.. I then use MORGAN vacuum gauges to sync. [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
I will try and get a few proper pictures of her outside tomorrow and post them for you..👍
Andy1488
Newbie
Nearly at the gym.
Reply #12 on:
April 28, 2022, 09:45:06 PM »
murdock
SOHC Member
Reply #13 on:
April 28, 2022, 09:49:27 PM »
I love it ! with that king and queen it looks great.
Do you have any idea where the clamps that you have on the forks will be?
me encanta ! con ese rey y reina se ve genial.
tienes idea de donde seran las abrazaderas que llevas en las horquillas ?
Andy1488
Newbie
Nearly at the gym.
Reply #14 on:
April 28, 2022, 09:56:05 PM »
No idea yet...... here's my go to ride.... [ Guests cannot view attachments ]
Carb 069A sync....
