Author Topic: Advice required re fork stanchions  (Read 8043 times)
Offline 3scs
Re: Advice required re fork stanchions
« Reply #15 on: May 06, 2022, 02:00:12 PM »
They are the same forks those are now fitted to my K3 as it had a set of F1 forks fitted to it when I bought it ,the F1 forks are for sale if anyone is looking for some they have been to Philpotts and rechromed and I’ve fitted new seals
« Reply #16 on: May 06, 2022, 02:21:20 PM »
Roo is looking for some stanchions, I reckon if you fitted the F1 tubes but with F2 innards it would help compress the springs better in case they'd got shorter as they aged and were used.
« Reply #17 on: May 06, 2022, 03:13:21 PM »
Hiya, Oddjob’s just sent me a link to this, how much do you need for them mate, I’m desperate for a set???
« Reply #18 on: May 06, 2022, 03:14:41 PM »
I might still want your innards though Ken if they’re up for grabs?
« Reply #19 on: May 06, 2022, 03:17:22 PM »
If you need to alter preload spring height, these https://www.ebay.co.uk/itm/313535590659 will likely fit and can be swapped/combined to give dimensions you want.
They're used in mtb forks (these Rockshox Boxxer) that are 35mm stanchion too.
« Reply #20 on: May 06, 2022, 04:11:22 PM »
Yeah you can have those Roo, just postage costs.
« Reply #21 on: May 08, 2022, 02:11:53 PM »
Cheers for the spacer infor, spot on.
Ken,start making a pile! ;) ;D ;D
