SOHC.co.uk Forums > CB500/550
Can ignition timing be set without power?
<< < (2/3) > >>
K2-K6:
Multi meter method ;- set to continuity with "beep" to confirm the circuit, remove wire from points to coil and attach one lead to that, the other lead to engine cases (earthing) all the time the circuit is connected it will beep, meaning not firing, as soon as the beep stops when turning crankshaft that's the firing point of timing.
deltarider:
--- Quote from: K2-K6 on May 11, 2022, 10:40:10 PM ---Multi meter method ;- set to continuity with "beep" to confirm the circuit, remove wire from points to coil and attach one lead to that, the other lead to engine cases (earthing) all the time the circuit is connected it will beep, meaning not firing, as soon as the beep stops when turning crankshaft that's the firing point of timing.
--- End quote ---
That's how it's done. If your multimeter does not feature 'a beep continuity' position, select Ohm and observe the digits go from 0 (closed) to I (open) or the dial move (analogue). Important is to disconnect the wire from the breakerpoints to the coil.
Rolfbulmer:
Thanks guys. Just what I needed, a clear set of instructions. I am looking forward to giving it a go.
Spitfire:
Here's my high tech version
Den
JezzaPeach:
If the adjustment range on rotating the back plate won’t seem to accommodate the firing point, it’s often just a question of adjusting the points gap (to smaller I think) as this makes a sizeable difference to the firing point.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
