SOHC.co.uk Forums > CB350/400
Reinstalling cam shaft.
<< < (2/2)
McCabe-Thiele (Ted):
I found it easier to fit the camshaft with the gear loose then when in position fit the bolts - give you some chain slack.
Oddjob:
That's the way it should be done Ted, it's too tight otherwise.
billdn:
--- Quote from: Matt_Harrington on June 06, 2022, 03:13:40 PM ---Go on, 'fess up!  ;)
--- End quote ---
Let's just say what happens in the shed but Ted's way works perfectly. Would helpkif I could tell my left from right.
Matt_Harrington:
 ;D
--- Quote from: billdn on June 06, 2022, 10:17:20 PM ---
--- End quote ---
--- End quote ---
I was always challenged by the cylinder number order number when the case was inverted - I ended up using a marker pen so I knew what side/end was what when casings are upside down for assembly & split etc.
Navigation
[0] Message Index
[*] Previous page
Go to full version
