Author Topic: Rear brake stay arm fitting  (Read 10077 times)
Re: Rear brake stay arm fitting
« Reply #15 on: June 07, 2022, 12:47:28 PM »
Oh dear. CMNSL picture which differs. Washer and spring washer. The rubber bush isn’t shown as it appears elsewhere in the fiche. ::)
That's the front bolt Phil, the rear is not a hex headed bolt.
« Reply #16 on: June 07, 2022, 01:03:28 PM »
Oops..so it is. Attached the wrong photo.
Offline Rolfbulmer
« Reply #17 on: June 07, 2022, 08:16:33 PM »
Thanks delta rider for the link to a previous forum discussion. Sounds like there are lots of different opinions, not helped by the inconsistencies in Honda manuals and schematics.
I am reasonably sure that the torque arm should not be tight at the brake end, and it would seem logical to me to have the rubber washer between the aluminium brake case and the steel torque arm, so this is going to be my set up when I get the new t-bolt from David silver.
1977 Honda CB550F - Cafe racer project bike
2001 Honda Hornet 600  - All weather bike
2019 Triumph Speedmaster 1200 - Dry and sunny weather bike
« Reply #18 on: June 07, 2022, 08:58:16 PM »
I was looking for a new T bolt a few weeks ago and IIRC DS didn't have one in stock.
Offline Rolfbulmer
« Reply #19 on: June 08, 2022, 08:01:38 AM »
Hi Oddjob,
I think its on back order. They have taken my order and sent an order acknowledgement.
« Reply #20 on: June 08, 2022, 12:46:53 PM »
I replaced mine with a shouldered stainless steel bolt, shaped the hex end to fit inside the opening in the brake plate. I also did the same with the front bolt.
Just in case DS lets you down.
