Author Topic: Cable runs  (Read 4189 times)
Offline bruxby-clive
Cable runs
« on: June 14, 2022, 04:17:02 PM »
Could someone please confirm the correct cable runs for the clutch and throttle cables on a 500K2. Thanks in advance.
Just because you are breathing, doesn't mean you are alive.
Online Oddjob
Re: Cable runs
« Reply #1 on: June 14, 2022, 06:09:15 PM »
Check the PDI instruction as there are diagrams for cable routing on there.
Re: Cable runs
« Reply #2 on: June 14, 2022, 09:14:01 PM »
Thanks Oddjob.
Re: Cable runs
« Reply #3 on: June 15, 2022, 06:30:04 AM »
What is meant by 'PDI'? I had a look at various Pre Delivery and Set up docs, but haven't found a diagram for cable runs.
« Last Edit: June 15, 2022, 06:39:30 AM by deltarider »
Re: Cable runs
« Reply #4 on: June 15, 2022, 06:31:33 AM »
 Behave yourself 😉
Online Oddjob
Re: Cable runs
« Reply #5 on: June 15, 2022, 01:16:27 PM »
You can use this.
file:///G:/Bike%20Info/Cb550F%20addendum%20and%20cable%20routing.pdf
It's for a 550 but that's not a big problem, carbs are in the same place.
