Author Topic: 12V feed for Wireless charger  (Read 6547 times)
Offline Bro550F
« on: July 20, 2022, 04:06:33 PM »
Hi,
As title says I'm hoping someone can tell me the best way to get a feed for my Quad Lock wireless charger from. I've currently (see what I did there?)  ;D, got it connected directly at the battery but obviously can't stay like that.
I want it to become live with the ignition on only.
Pointers to which wire and location please.
TIA
Re: 12V feed for Wireless charger
« Reply #1 on: July 20, 2022, 07:37:36 PM »
Neg to frame(or green wire) Pos to black wire at ignition switch
« Reply #2 on: July 21, 2022, 08:23:03 AM »
Depends on your exact model. My model has a blind black female connector not used in Europe because of a different wiring to the horn. I've used that one. So... again... identify your specific model (area code!) and then consult the appropiate wiring diagram.
Offline Bro550F
« Reply #3 on: July 21, 2022, 11:24:08 AM »
Thanks guys.
Will look for a black wire close to where I want to mount.
« Reply #4 on: July 21, 2022, 12:52:05 PM »
On my model it is here (blue arrow in pic below). It is conveniently positioned close to the tool tray, where I keep my USB connection for when I need it.
Offline Bro550F
« Reply #5 on: July 21, 2022, 04:38:23 PM »
Perfect, thanks.  Not checked yet but If I haven't got a spare female I'll join it to a convenient black.
« Reply #6 on: July 21, 2022, 05:00:58 PM »
Surely that connector is under the tank next to the coils, if the horn wiring is next to it that's where it will be. It was originally there to feed the horn IIRC as the horn was fed by the black wire and the light green earthed it but they changed the way the wired it and in effect reversed the wires, hence why there is a small earth wire with a green band around it.
« Reply #7 on: July 22, 2022, 06:24:24 AM »
When you zoom in at the connectors inside the headlamp bucket, you will see other blind female connectors for your device both BLACK and GREEN.
Offline Bro550F
« Reply #8 on: July 22, 2022, 08:26:06 AM »
Will have a look inside the headlight bucket.
Thanks.
Offline Bro550F
« Reply #9 on: July 26, 2022, 09:05:35 PM »
Thanks.
I did indeed find a spare black and green female bullet connectors, so snipped off my eye connectors and soldered 2 male bullets.
Job done, comes on with ignition.
Thanks all.
