Author Topic: CB 500 resurrection  (Read 92636 times)
Re: CB 500 resurrection
« Reply #210 on: October 01, 2022, 05:19:35 PM »
The DS brackets may need a bit of tweeking but the pattern ones are all made by the same people. Genuine ones ,both new and used, do come up on fleabay occasionaly but usually in US. I think Ash did some comparrisons of pattern to genuine and put measurements up but not sure
Offline gary123
« Reply #211 on: October 01, 2022, 05:40:29 PM »
OK thanks
« Reply #212 on: October 01, 2022, 07:07:13 PM »
That place in Stoke, can't remember the name, had some genuine ones for sale a few weeks ago.
« Reply #213 on: October 02, 2022, 08:06:15 AM »
DK Ken?
Offline gary123
« Reply #215 on: October 02, 2022, 12:22:06 PM »
Yes I did see them but together there more expensive than the DS new ones. Ill try make an offer.
Offline SPR
  • 1972 500/4 K1
« Reply #216 on: October 02, 2022, 12:24:39 PM »
Thing is they will probably fit without hassle ......
« Reply #217 on: October 02, 2022, 01:38:19 PM »
DK Ken?
Yeah, DK, I kept thinking DS but of course that's Dave Silver.
Gary, get the 2 lowest priced ones and have them powder coated. Even genuine Honda ones are not painted very well, I had a NOS one recently and that had an awful finish.
I checked my BILs DS brackets against my genuine ones, the lower ones were well out, the uppers weren't that far out but saying that I couldn't say they were that way when bought as he could have bent them trying to get the exhausts to line up.
Ash did a thread about the DS brackets compared to genuine, you can find it if you look.
« Last Edit: October 02, 2022, 01:48:45 PM by Oddjob »
Offline gary123
« Reply #218 on: October 08, 2022, 07:47:23 PM »
Well I went for the DS ones and they went on with no real problem. One side was a bit tight but that could be due to the after market exhausts on that side.
Offline gary123
« Reply #219 on: October 11, 2022, 07:59:27 PM »
So today I couldn't resist a trial start up. After 5 or 6 tries it started and ran and revd. BUT then I saw smoke/fumes coming from the generator cover, through the holes that hold the Honda badge on. I removed the cover and it looks like the rotor is very slightly rubbing the stator. I do have another of each, should I try swapping or will it "bed in" and settle down. The cover was VERY hot.
« Reply #220 on: October 11, 2022, 08:06:20 PM »
Is the rotor really rusty?
« Reply #221 on: October 11, 2022, 08:06:36 PM »
It definitely will not bed in - there should be no contact between rotor & stator.
Offline gary123
« Reply #222 on: October 11, 2022, 08:07:34 PM »
No not rusty at all.
« Reply #223 on: October 11, 2022, 08:09:40 PM »
Dismantle and see where the wear marks are.
« Reply #224 on: October 11, 2022, 08:11:17 PM »
Is it the right rotor for the engine & is it bolted up tight?
The stator is held in place with a series of 3 or 4 bolts into the housing.
Is it the correct housing & stator?
