Author Topic: Ultrasonic cleaner solution for carb parts etc  (Read 4547 times)
« on: July 27, 2022, 09:37:02 AM »
I have a small ultasonic cleaner that we used for cleaning some old jewelery - its not large but okay for smaller items such as jets, emulsion tubes, carb bowl etc.
Can anyone recommend a cleaning solution please?
Re: Ultrasonic cleaner solution for carb parts etc
« Reply #1 on: July 27, 2022, 10:05:54 AM »
Concentrated screen wash diluted 50/50 with de ionised water.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #2 on: July 27, 2022, 12:59:58 PM »
Ted, if possible try using a hot mix too… definitely softens up the dirt a bit better.
Offline ST1100
« Reply #3 on: July 27, 2022, 05:31:01 PM »
Definitely hot, but wouldn't go over 60°C... (discolored some painted brake calipers by going to 80°C...)
STOC #637
Offline Matt_Harrington
« Reply #4 on: July 27, 2022, 06:12:58 PM »
Screenwash is a good idea. If you want a formula designed for carbs, these guys market various potions!
https://www.allendale-ultrasonics.co.uk/ultrasonic-cleaning-solutions-and-powders
I tend to run mine at about 50 to 60degC.
oldchuffer
« Reply #5 on: July 27, 2022, 07:09:33 PM »
I'll second that. I've used carb solution from Allendale and it works a treat.
« Reply #6 on: July 28, 2022, 08:33:12 AM »
Allendale every time. I use it at 70c👍
« Reply #7 on: July 28, 2022, 10:15:32 AM »
Ditto…allandale.
Offline alfiembra
« Reply #8 on: July 28, 2022, 12:13:21 PM »
If you have enough room in your cleaner use an old glass jam jar or similar with petrol in it. Put your parts in the jar then into just plain water in the cleaner. Just enough water so that the water displaced by the jar doesn’t spill out the cleaner. The jar also contains all the muck cleaned off the parts.
« Reply #9 on: July 28, 2022, 01:08:04 PM »
I watched Junk & Disorderly last week (must watch TV if you are a biker) and Alan Millyard told Henry Cole that you must not put your fingers into an ultrasonic bath when it is working as the ultrasonic waves will kill the nerves in your fingertips and you'll end up losing the finger. Is this true or was Alan joking, nobody was laughing but surely a domestic ultrasonic cleaner isn't that powerful?
As an aside poor old Alan had a nasty 'off' last week when the Triumph chopper they bought refused to turn!
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #10 on: July 29, 2022, 12:20:53 AM »
Funnily enough I’ve been dunking my fingers a fair bit of late into my ultrasonic bath. An odd and mildly unpleasant sensation, can’t really describe it. But, whilst I have a growing distain for ‘authority’ etc, surely if such cleaners maimed folk they’d have been outlawed long ago?
PS… fingers all present / correct and pink. Phew. Furthermore, they’ve survived a few years ownership of a V Twin MotoGuzzi, which leave my hands numb after an hour 😬
« Last Edit: July 29, 2022, 02:10:54 AM by Lobo »
« Reply #11 on: July 29, 2022, 12:26:34 PM »
I've tried the glass jar with petrol & it seems to have worked quite well on the brass ware - my Ultasoc bath is not large enough to put a carb body in a jar but great tip.
I've ordered some Allendal Carb Cleaner to try as well.
« Reply #12 on: July 29, 2022, 01:28:31 PM »
Nice one Ted👍. Make sure you rinse the carbs after using the Allendale cleaner to stop any white deposits appearing after a few days.
