Author Topic: Clutch cover removal  (Read 4652 times)
Offline Davelu88
« on: July 28, 2022, 01:46:51 PM »
Hi All , after alot of swearing and threatening to scrap the bike the engine has finally let me get out all the screws holding the clutch cover on , however it does not want to let go of the cover so easily,  anybody got any tips to get it off as I think this maybe the first time it has been apart .
Thanks Dave
Re: Clutch cover removal
« Reply #1 on: July 28, 2022, 01:55:33 PM »
There are 2 dowels holding the casing to the crankcase. They have most likely rusted a bit and bonded into the case.
Rubber hammer and some heavy hitting usually does the trick. You could also try pulling the clutch in as the action should force the cover away from the crankcase. Don't try and lever it off.
Just bought a pile of parts for the 550 just yesterday, there are around 5 clutches in the job lot so if you ruin the casing I can let you have a spare cover dirt cheap.
Offline Davelu88
« Reply #2 on: July 28, 2022, 02:03:04 PM »
Many thanks Oddjob, 😊
« Reply #3 on: July 28, 2022, 02:05:57 PM »
Try the clutch action first, it often works. If not try holding the clutch in whilst hitting the case with a rubber mallet. A compethane hammer is best, a dead blow one with lead shot inside.
Offline Davelu88
« Reply #4 on: July 29, 2022, 07:43:19 PM »
Got cover off with rubber mallet , but this washer fell out ? Looked at schematics but still not sure as don't  seem to fit anywhere.
« Reply #5 on: July 29, 2022, 07:50:37 PM »
It goes on the kick start shaft so, the shaft doesn't wear the case   ;)
Offline Davelu88
« Reply #6 on: July 29, 2022, 08:03:30 PM »
Many thanks Trigger 😊
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #7 on: July 30, 2022, 10:23:08 AM »
Just a suggestion (you may well already do!) from when I did mine (excellent 500 push rod supplied by Trigger!) I used a fine wood chisel (and heat as suggested by Julie) to scrape the old gasket off. I found the chisel more controllable that eg a craft blade which tended to skid or dig in.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline Davelu88
« Reply #8 on: August 02, 2022, 11:47:09 PM »
Thanks Jezza , I will have a go at that as gasket stuck on firm in parts  ;D
