Author Topic: Back with a 500 ....  (Read 109184 times)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: Back with a 500 ....
« Reply #90 on: September 12, 2022, 02:45:03 PM »
Got it, each new message has a box, bottom left, to tick to “save message in outbox”
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #91 on: September 12, 2022, 02:48:45 PM »
If you got to settings i think you can do all messages and not individualy
« Reply #92 on: September 13, 2022, 12:33:05 AM »
Doneit, nice one chaps...
Beat you Jezz ;D 8)
Offline JezzaPeach
« Reply #93 on: September 13, 2022, 06:48:01 AM »
Found it! 🏍 ;D
Many thanks!
Hondaman kit on the way  :)
« Reply #94 on: September 16, 2022, 10:52:13 PM »
Came today Jezz all present and correct mate. Already in my bag for you bud.
Offline JezzaPeach
« Reply #95 on: September 17, 2022, 02:34:07 AM »
Fantastic thanks Roo. Something to look forward to!  ;D
Offline SPR
  • 1972 500/4 K1
« Reply #96 on: September 24, 2022, 05:42:02 PM »
Small things :)
Matching locks throughout
Simon
Offline SPR
  • 1972 500/4 K1
« Reply #97 on: October 08, 2022, 02:05:16 PM »
Carb balancing note to self ........... check the pipes match left to right on the bike  ::)
Took best part of an hour with a coffee break whilst pondering why any adjustment wasn't reflecting where I thought it should on the gauge ..... then realising I'd got the tubes back to front !!!
Then the hardest part was snugging the lock nuts without altering the readings too much.
Result is though far less noise at idle and actually idles at 1050 no problem - and even a bit lower when really warmed up
« Reply #98 on: October 08, 2022, 04:39:11 PM »
Thats why you use the special long socket with screwdriver through it
« Reply #100 on: October 08, 2022, 04:45:20 PM »
Thats the one
Offline SPR
  • 1972 500/4 K1
« Reply #101 on: October 08, 2022, 04:48:40 PM »
Thats the one
Brilliant - thankyou :)
« Reply #102 on: October 08, 2022, 07:46:12 PM »
And this is what I've always used. A simple 8X9 mm pipe wrench in combination with an ordinary wrench on top. I hope you can see in the pic, there's a piece of vinyl tube over it 1 cm from the pipe's end where the ordinary wrench goes, to prevent the latter from sliding down the pipe. Inside the pipe wrench an ordinary straw to narrow the passage to guide the appropiate screwdriver better. Not super, but it worked for me and cost nothing. You could also weld the wrench to the pipe, but I never bothered. Except for the screwdriver, both pipe and wrench fit in your Honda tool bag. Don't you love simplicity? ;)
Offline SPR
  • 1972 500/4 K1
« Reply #103 on: October 08, 2022, 07:48:48 PM »
I'm sure I've one in the toolbox !! Cheers I'll be looking for it tomorrow :)
« Reply #104 on: October 08, 2022, 11:47:58 PM »
Like this Bryan ?
Bugger, I paid 27 quid for mine some years ago, I see they're now 11. I feel slightly grumpy about that, ney, addled!!
