Author Topic: Where can I find these headlight brackets?  (Read 12724 times)
Offline alexdecker
« on: August 05, 2022, 12:53:31 PM »
These are nice. Not original I assume though. Does anyone know where they are from?
Also, is the front signal lights the same as the back ones? Mine does not look so similar at all!
« Last Edit: August 06, 2022, 02:20:52 PM by alexdecker »
Re: Where can I find these headlight brackets?
« Reply #1 on: August 05, 2022, 01:09:02 PM »
picture? ;D :o
Offline alexdecker
« Reply #2 on: August 06, 2022, 02:21:09 PM »
Haha, sorry. Has picture now!
« Reply #3 on: August 06, 2022, 06:38:32 PM »
I fitted these to Julie's 550 mongrel some years ago. Comes with a universal kit with is a bit of a pig to fit but, once on are fine >>> https://www.ebay.co.uk/itm/164200032023?hash=item263b15a717:g:U0EAAOSwBgtZvJvG
« Reply #4 on: August 06, 2022, 08:39:15 PM »
That’s a really nice bike there Alex, particularly like the black and cream/white paint job and the gold rims. Very tasteful conversion IMO.
« Reply #5 on: August 06, 2022, 09:05:31 PM »
Wow Alex is that your bike it looks well tidy?
« Reply #6 on: August 06, 2022, 09:06:18 PM »
Has that had a turbo fitted?
I don't think that's Alex bike as he still hasn't sorted the indicators out yet to my knowledge. Plus it's a K3 and Alex has an F2.
Offline alexdecker
« Reply #7 on: August 07, 2022, 06:26:49 AM »
Thanks! These look like they could do the job. I just saw a lot of brackets with holes in them and other silly looks, and those on the bike in the picture came a little nearer to a stock look without being it.
I’ve also considered a Bates style headlight, but not sure how to fit it, and would rather not drill into the yoke or anything like that. Does anyone know what kind of assembly those headlight take?
Offline alexdecker
« Reply #8 on: August 07, 2022, 06:35:26 AM »
Uh no, not my bike. This is one from the US forum I think, just liked the brackets because they had an OEM look, and wanted to see if I could source them.
Here is a picture of my bike. Looks normal enough. On closer inspection though, the chrome is pretty beat up, there is holes in the fender etc. But I wanted it to run good before I make it look good. So went through the engine first. Now I am starting to try and do the cosmetic work. I decided not to do a restoration, but more like a resto mod, as it is hard sourcing all the original parts. But I like the OEM look, so trying not to stray too far from that. Need fenders, signal lights and front and back lights, and a new paint job, and then we are looking pretty good I think. So working on it over the winter (like everybody else I assume).  Right now I just wanna ride it a bit and see how the engine runs after I went through it 😊
« Reply #9 on: August 07, 2022, 07:53:14 AM »
Just use your honda headlight. If you scroll down this link, you will find pictures of my black 550 with those headlight brackets.  http://www.sohc.co.uk/index.php/topic,24825.75.html
Offline alexdecker
« Reply #10 on: August 07, 2022, 08:54:03 AM »
Nice, thanks Julie! I might just end up doing that. Those brackets look exactly like I want them.
Are you just using stock signals? The chrome on mine are rusted and pitted, so looking for a nice replacement.
Also - no rear fender? Only riding in dry weather, or have you worked out a less visible solution?
« Reply #11 on: August 07, 2022, 12:19:45 PM »
You're missing the speedo cable bung. Goes in the hole in the front mudguard and the speedo cable passes through it. OE one is a sort of dirty white/grey colour.
« Reply #12 on: August 07, 2022, 01:17:36 PM »
Offline alexdecker
« Reply #13 on: August 08, 2022, 05:31:59 AM »
Replacement indicator stems >>>  https://www.davidsilverspares.co.uk/CB500K0-FOUR-1971/part_351532/
Ah! Are these usable without any other parts in both front and back?
« Reply #14 on: August 08, 2022, 06:26:56 AM »
On the front only. The back stems are totally different  ;)
