SOHC.co.uk Forums > CB350/400
Headlight main beam warning light - CB400/4 F2
<< < (2/2)
flatfour:
Many thanks to all for your helpful advice.
I'll pass it on and let you know the outcome.
McCabe-Thiele (Ted):
--- Quote from: Athame57 on August 30, 2022, 01:00:09 AM ---
--- Quote from: Oddjob on August 29, 2022, 11:57:35 PM ---It’s possible the bike has been fitted with a David Silver wiring harness, these are known to not follow the same colours as the original Honda wiring harness.
--- End quote ---
This is what I have, and no, the colours do not always make sense. Is the DSS version US spec or something?
--- End quote ---
Not 100% sure but I think the UK & US versions have the same loom so you are left with some spare wires.
Bryanj:
The theory is looms are the same but switches differ between countries
Oddjob:
--- End quote ---
--- End quote ---
Reports from members who have fitted a DS loom is that whilst all the connectors are correct the wire colours are not. Some are but a lot differ, for instance a red/white wire could be a red/yellow on a DS loom. If you do a search of the forum you can see members asking for advise on how to wire them up but most return the loom as it's not really good enough. Ok I suppose IF you have some electrical knowledge of the bike but otherwise it's confusing as hell.
There was a thread just a few weeks ago, which is why it was fresh in my mind.
That why I avoided the DS unit after reading about them on this site - the one from Elextrex had identical colours to my original loom they have gone up quite a bit since 2020 when I bought mine..
https://www.electrexworld.co.uk/acatalog/WH-377.html#SID=1158
Navigation
[0] Message Index
[*] Previous page
Go to full version
