Author Topic: Teds new project a CB500 K1 mostly version 0.5 circa 1972.  (Read 298689 times)
Online McCabe-Thiele (Ted)
Re: Teds new project a CB500 K1 circa 1972.
« Reply #270 on: October 22, 2022, 02:40:35 PM »
Tbh Simon I'm well in front of where I was when I stripped down the 400. It's been easier as the bike has been dismantled before. Even the centre  stand pivot came out undamaged.
Progress will come to a crawl as the weather gets cooler in the garage. I plan to improve on surface preparation - something you can't rush before I start up the rattle cans.
Offline gary123
« Reply #271 on: October 22, 2022, 03:28:59 PM »
Making good progress, Im enjoying watching this.
Offline Matt_Harrington
« Reply #272 on: October 23, 2022, 04:30:32 PM »
Ted, I'm sure all this hard work will be worth it!  ;) Great progress.
« Reply #273 on: October 28, 2022, 02:53:56 PM »
Picked the frame up from the powder coaters today - good thing  is you can still see the stamped frame number.
Used a different powder coater this time RPT Engineering Ltd at Somercoates DE55 4LS Cost with VAT was £190 including stands, swing arm, battery box & rear frame grab rail part.
Not as thickly applied this time so well pleased with the  30% gloss black finish.
.500 K1 frame by Macabe Thiele, on Flickr
Offline gary123
« Reply #274 on: October 28, 2022, 03:46:51 PM »
Looks good Ted. I like the low gloss look.
Might have been better in brown ;D
« Reply #275 on: October 28, 2022, 04:53:49 PM »
Beige would have looked better but loving the black Ted, well done mate
« Reply #276 on: October 28, 2022, 05:06:05 PM »
I will save the high gloss  black for the Tank & Panels (eventually).
« Reply #277 on: October 28, 2022, 05:12:28 PM »
BEIGE how very dare you Roo it was Nut Brown !
Offline smoothoperator
« Reply #278 on: October 28, 2022, 05:31:43 PM »
Looking great Ted, rapid progress! Good that you've found a better powder coater.
Steve
2017 Triumph Bonneville T100
« Reply #279 on: October 28, 2022, 06:31:09 PM »
What's going on with the bottom rail, near the footrest mount Ted? Looks like something is on it.
« Reply #280 on: October 28, 2022, 07:51:36 PM »
Angle of the photo - the background is front wheel ramp clamp?
Offline SPR
  • 1972 500/4 K1
« Reply #281 on: October 28, 2022, 08:08:48 PM »
That does look well ...... I've had a spare swing arm done and it had to be gloss to match the rest but much prefer the slightly less gloss finish
« Reply #282 on: October 29, 2022, 06:39:33 PM »
A little more progress this afternoon - rear swing arm Brass bushes fitted plus shocker mount bushes - a couple of days in the freezer made the first 75% of the fitting easy - then use alloy drift tool and a big rubber hammer they fitted far too easily.
Spent a good 30 minutes looking for the rear brake pivot that I finally found in a takeaway box with rear brake pivot written on it. Work has ground to a standstill now until I find the return spring that was not in the box.
DS say its discontinued so another day for that search party - I have a feeling I put it somewhere too safe to find easily - keeps me fit I guess looking in the same places as before several times over.
Run out of beer so having to drink some Pineapple & Passion Fruit Cider (4%) to make do for tonight.
« Reply #283 on: October 29, 2022, 06:47:22 PM »
Is it on the brake rod? That's where I usually put it.
Enjoy your cider, I'll have one too! 🍻
« Reply #284 on: October 29, 2022, 07:48:31 PM »
No - I am looking for a circular spring I take it 46514-323-020  I assume - found the pedal & the rod definitely a job for another day I must have looked in three shelves of boxes plus umpteen big boxes on the floor four times over - at least as you progress it gets easier with fewer parts to look through..
« Last Edit: October 29, 2022, 08:27:13 PM by McCabe-Thiele (Ted) »
