Author Topic: Honda Throttle grip adjuster ramp 53163-300-020  (Read 7449 times)
Re: Honda Throttle grip adjuster ramp 53163-300-020
« Reply #15 on: October 28, 2022, 07:39:06 PM »
Yeah, already had one ear marked for you Ted.
You drilled and tapped the switch gear yet?
No not yet I'm months away from that. Failing to plan is Planning to fail.
« Reply #16 on: October 30, 2022, 12:16:53 PM »
Well after working my sums out it appears I may have got a bit of a bargain when I bought these, so revised price is £12 for spring and thumb screw inc P&P. £5 more if you buy the ramp at the same time. All are brand new, in perfect condition, no rust or corrosion.
« Reply #17 on: October 30, 2022, 02:53:01 PM »
When do you want my money Ken?
« Reply #18 on: October 30, 2022, 03:44:04 PM »
Whenever you're ready Ted.
« Reply #19 on: October 30, 2022, 06:38:32 PM »
PM'd my address dosh on its way.
Offline philward
« Reply #20 on: October 30, 2022, 07:13:24 PM »
If you have all 3 parts (full set) left, I'll have a set please Ken
« Reply #21 on: October 30, 2022, 08:23:48 PM »
Yes Phil I still have all 3 parts needed.
You know the PayPal address I presume.
Offline philward
« Reply #22 on: October 30, 2022, 08:35:06 PM »
Just sent money Ken - have you still got my address?
« Reply #23 on: October 30, 2022, 08:41:53 PM »
Yeah Phil, already packed up and will be sent tomorrow.
Cheers.
Offline philward
« Reply #24 on: October 30, 2022, 08:43:14 PM »
Cheers Ken, much appreciated
« Reply #25 on: October 30, 2022, 08:53:02 PM »
Does your right hand switchgear have the little threaded hole between the cables Phil, it should have if it's a 500 piece.
Offline philward
« Reply #26 on: October 30, 2022, 09:05:44 PM »
Its for my 750k2 (500 already has a set). Just checked and its got an m5 thread
« Reply #27 on: October 31, 2022, 01:01:40 AM »
That's fine then Phil, same setup as the 500.
Offline philward
« Reply #28 on: October 31, 2022, 09:03:44 PM »
Cheers Ken
Offline Erny
  • CB750K7 CB550K1
« Reply #29 on: November 08, 2022, 10:44:05 PM »
Hi Ken, if still available, I'd take full set too (all 3 needed parts)
CB750K7 US model (1977)
CB550K1 US model (1975)
