SOHC.co.uk Forums > CB500/550
CB500 upper front brake hose routing
Bryanj:
No i dont have the covered stuff, just the hose and fittings left over from a few years back
SPR:
--- Quote from: McCabe-Thiele (Ted) on September 17, 2022, 09:42:47 PM ---Might be the change of route will loose some of the excess hose - worth a try just cost a bit of brake fluid.
--- End quote ---
Yep worth a go
SPR:
Good shout by Ted ......
Stripped the calipers to give it a quick coat of paint and flushed the system to use DOT5 .... rerouted the upper hose and also the two throttle cables
The hose may still be a little long but a test ride shows all works as well as before and the headlight area certainly looks better for moving everything
Simon
McCabe-Thiele (Ted):
Just a word of caution Simon the Silicon Dot 5.0 is not miscible with any other brake fluid - if possible use only after a full dismantling with clean master cylinder, caliper innards, flexi hose & pipes.
If you have just drained the master cylinder & pumped out the fluid using some Dot 5.0 as a flushing agent then after standing for a day I would pump out some fluid from the caliper bleed nipple into a glass test tube or similar to check for traces of the old fluid.
The new silicone fluid will float on top - the old fluid will be in a puddle at the bottom like a sediment.
PS Don't ask how I know this.
A short ride might help the shake down.
SPR:
--- Quote from: McCabe-Thiele (Ted) on September 19, 2022, 04:54:06 PM ---Just a word of caution Simon the Silicon Dot 5.0 is not miscible with any other brake fluid - if possible use only after a full dismantling with clean master cylinder, caliper innards, flexi hose & pipes.
--- End quote ---
Thanks Ted
All was cleaned prior to use but there could still be residue in the hoses so I plan on further changing of fluid again in a few days
Simon
Navigation
[0] Message Index
[*] Previous page
Go to full version
