Author Topic: CB 500 K1 running issue  (Read 14717 times)
Offline Beefington1975
Re: CB 500 K1 running issue
« Reply #30 on: September 20, 2022, 09:19:15 PM »
Just a thought...saw someone on another thread suggest that engine oil level could be a factor? I've checked mine and it's on the top line. The deposits on the plugs look dry, but could the fouling be due to excess oil???
I would only expect a high oil level to become an issue at high engine rpm due to excessive oil misting
OK. Thank you. I'm grasping at straws I think
« Reply #31 on: September 20, 2022, 09:32:30 PM »
As Ted indicated, I stood don't feel there is any effects likely from this. They have more tolerance to raised oil level that this amount.
Wouldn't discount the air filter as suspect though. Any significant impairment with this will impact that mixture and not be readily evident from just looking at the filter. Definitely worth trying with it removed to at least give you a check on condition and flow impact to running. Easy and costs nothing too.
« Reply #32 on: September 20, 2022, 09:42:27 PM »
Ok. Thank you. Will try it with the air filter out 👍
« Reply #33 on: September 22, 2022, 05:41:48 PM »
Try with the screws set at 2 1/2 turns out and see if that gives anything in the way of sensible running, or improvement at all.
It does appear to be too rich.
Do you know which size of idle jet is fitted to them ?
More rudimentary check is to remove air filter and see if that improves running.
Really just trying to get further assessment to help indicate what may be out of kilter.
Had some time to tinker today
I removed the in-line fuel filters and ensured the fuel lines were stock length.
I then wound the air-screws out to 2.5 turns and took the bike for spin.
It ran very well, a pleasant surprise. I covered about 10 miles - mostly low speed (30 - 40 mph) with a few bursts of speed (up to 60mph) . No poor running evident. Checked the spark plugs and they seem 'normal'/optimal
Not sure what this means - as it ran much better at a non-stock setting.
« Reply #34 on: September 22, 2022, 06:11:33 PM »
For some reason it seems to be getting just a little excess fuel at the very low end of carb range.
Setting the screws out further will not change the metered fuel from idle jets at their maximum (roughly half way through carb opening) as that's controlled by the 40 sized orifice. What the air modulation does is to change the "ramp" angle leading to that point by bleeding more air through than fuel at the very base of throttle slide opening.
Honda don't state an absolute for this setting of air jet, more a competent start point to be refined during setup. Obviously this case you can see the response from resetting them (indicating circuits are working reasonably) and ending up at 2.5 out is probably at the far end of range reality, but not unworkable. Probably more assessment is valid here to see if you've any unwanted complications and perhaps see if anything else is out of the ordinary over further mileage.
At least if it runs well you've got a chance to now get more comprehensive view.
The inline filters, I'd definitely not associate with low speed fuel demand and feel confident to discount those in this area of carburetor work. Usually it's peak flow that is of concern with these and inadequate supply volume to replenish float chambers fast enough when flat out and wide open throttle.  The float chamber of course acts a constant reservoir to the jets and will ordinarily have no problems at low speed.
« Reply #35 on: September 22, 2022, 06:26:11 PM »
That makes sense. I'll run it as-is for a while and keep monitoring. Will change the air filter too to rule that out as a factor.
Thank you for the generous help and information - it's paying off and I've learned a lot.
« Reply #36 on: September 22, 2022, 06:34:04 PM »
The last few of posts got me tinkering with my 500 K1 as it's raining. I have been unable to get it to idle at low speed it just cuts out or runs at over 2k rpm - let off the main stop screw just a fraction and it stops.
I've not done anything to the carbs as I was not too bothered about how it runs as long as I can try out all the gears on a short run.
So I checked the four air screws - they were all set at around 1.5 turns. I moved them to 2 turns then fired her up and let off the throttle stop screw a tad again - she now idles quite comfortably at around 1200 rpm. Yes not perfectly even yet  but so much better than it was - gives me more confidence that it will not conk out on a run now.
« Last Edit: September 23, 2022, 04:12:44 AM by McCabe-Thiele (Ted) »
« Reply #37 on: September 23, 2022, 02:12:56 PM »
Takes a little time back and forth to work through things, but beneficial in giving you a clearer picture. At least it appears now workable and you get to enjoy riding it too, so all good.
Hopefully it will stay stable but you may need to consider again if air filter proves to flow a little more easily.
Let us know how you get on.
« Reply #38 on: September 23, 2022, 02:33:44 PM »
Yes Ted, it's a valuable tool to trim slow speed running. So often the manual specification is referred to as an absolute which I don't feel is what Honda meant it to be. These carbs are very accurate/repeatable/concise but with other elements affecting the critical metering of fuel in such small quantities, then valid adjustment is entirely practical.
Their method (Honda manual script) is a very benign but far reaching routine that's often missed when considering setup. In effect, it takes account of, successively;- fuel specification, air flow, valve efficiency in sealing, piston rings, dynamic compression, ignition performance, air density, barometric pressure (height above sea level) to fine trim the the slow speed running.
It is exactly what fuel injection system accomplishes with use of Oxygen sensors reporting from exhaust to trim the mixture for prevailing mechanical and atmospheric conditions. Not in such a repeating timeline, but the same process but using you as it's view of how it's running.
Turning airscrew out (not pd carb, they're opposite usually) brings the mixture toward to lean at probably 14:1 ish when it will start to miss partially, then back in to richen slightly (rpm drop by approx 100) to probably end around 12.7/13.0 to 1 at which point it idles well.
Fuel injection does exactly thus, with short duration trim values to cope with immediately occurring emmisions, then aggregated into "long term trim values" that the ECU keeps updated to maintain overall mixture given the equipment it's working with. If the long term trim values reach certain threshold then the ECU will throw a code giving "emmisions" warning, or needing workshop attention.
Our emmisions code for these would be roughly 1/2 to 3 turns out for nominally general operating conditions. Outside those we would consider then to exhamine components to find cause.
Dammed clever those Kiehin designers  :)
« Reply #39 on: September 25, 2022, 05:17:01 PM »
An update.
I had a very satisfying run out today. The bike performed well, no sign of the previous problems. If anything, I'd say the engine feels more responsive and 'free running'.
Covered about 40 miles this time. Checking the plugs at the end shows a little soot on the end of the threads and the  bottom electrode, but the centre electrode and ceramic look ok.
Very pleased to have been able to enjoy a ride without trouble!
« Reply #40 on: September 25, 2022, 08:16:53 PM »
Have the fuellines as close to original as possible and use that clamp! Realise there's not that much column to speak of and flow is impeded easily. Therefor: no extra filters!
« Reply #41 on: September 25, 2022, 09:05:25 PM »
As long as the tank filter is intact everyone says that's enough.
On my 400 there was loads of space to fit a loop round the tool tray.  My 500 has no space so I will have to remove the tap & check it is good - the one on my 400 was full of holes!
« Last Edit: September 25, 2022, 09:11:07 PM by McCabe-Thiele (Ted) »
« Reply #42 on: September 25, 2022, 09:40:39 PM »
My petcock - the later model without the bowl and the nylon filter protruding into the tank - is still the original. I've bought a spare seal though that goes between the tank mount and the petcock in case I might need it. Oh, you will not find it if you consult the fiches, but I got the part number by chance as it also used on some Honda outboards and CMSNL has it separate for € 4,-: https://www.cmsnl.com/products/o-ring118x355_16997467000/.
« Last Edit: September 25, 2022, 09:42:27 PM by deltarider »
Offline Erny
  • CB750K7 CB550K1
« Reply #43 on: September 25, 2022, 10:17:46 PM »
Delta, this O ring is to seal what?
CB750K7 US model (1977)
CB550K1 US model (1975)
« Reply #44 on: September 26, 2022, 11:21:04 AM »
Sorry for explaining it poorly, it's the big one here: https://www.cmsnl.com/honda-cb500k2-general-export_model50441/strainer-set_16952341671/
By buying the seal separately, I didn't have to buy that complete strainer set. Last time I had mine off, the seal looked aged. That's why I ordered a spare one.
