SOHC.co.uk Forums > CB350/400
Charging system issue
Bryanj:
That probably means thr contacts in the reg are vibrating between zero and either halh or full charge.
There is a document, in alladins cave i think, called 3 phase charging which explains with diagrams how the system works
Ceeby-jeebies:
Thanks although it is a brand new regulator rectifier from David Silver that I fitted on Thursday
Bryanj:
Never liked the electronic versions personally, too fragile for me
Oddjob:
Have you tried another field coil or stator coil? Just to see if the fault goes away, sometimes swapping parts is quicker than fault finding.
Ceeby-jeebies:
Turned out to be a loose stator wire. Now fine when soldered back in. Thanks to all
Navigation
[0] Message Index
[*] Previous page
Go to full version
