Author Topic: CB200 carb issues  (Read 29859 times)
Re: CB200 carb issues
« Reply #90 on: March 12, 2023, 03:21:36 PM »
Get the 500 out JW. You know it makes sense.
Did about 25 miles on the 500,
Like riding an electric motor,
The 200,after removing caps to measure, and refitting carefully ran  better,
Under load full throttle nearly 7k,
Pull the clutch in,revs increased to 9k but not rapidly,
Coming back down a slope it revved to nearly 8k on two thirds throttle, pulling the clutch in,the revs shot up to nearly 10k quickly
Your thoughts, gentlemen
« Reply #91 on: March 12, 2023, 03:32:21 PM »
You checked for an air leak John?
« Reply #92 on: March 12, 2023, 03:38:53 PM »
Initially sounds lean at top end.
« Reply #93 on: March 12, 2023, 03:40:51 PM »
Any plug colour after it's been running at full temp ?
« Reply #94 on: March 12, 2023, 04:08:38 PM »
Without trawling through the whole thread have you checked the jet sizes to see if they are standard? Same for clip position, it's an old bike and old owners could have altered all sort of things back in the day.
« Reply #95 on: March 12, 2023, 04:44:15 PM »
Definitely seems to have moved to fuelling.
« Reply #96 on: March 12, 2023, 05:49:31 PM »
Okay
Standard jets
Full standard air cleaners
I thought lean,so I operated the choke, no benefit
New manifold and carb O rings
« Reply #97 on: March 12, 2023, 05:53:45 PM »
Is clip position alterable?
« Reply #98 on: March 12, 2023, 06:05:49 PM »
Tried it previously
Lifted the needle one slot,
Sooty plugs and rough running
also tried  95 MJ instead of 88,  no difference,
sure the spark is not failing under load?
« Last Edit: March 12, 2023, 06:20:23 PM by Johnwebley »
« Reply #99 on: March 13, 2023, 08:45:51 AM »
Mixed signals in whats happening there John.
Obviously, as noted by Ted, the only real way of eliminating the coil conclusively is by substitution to assess that effect.
Try running it in the dark to see if you're getting any HT leakage, I've been caught out on some leads like that before, seemed to function well but looked like a hairy caterpillar in the dark  ;D they were leaking a fine "mist" along entire length in damp air.
« Reply #100 on: March 13, 2023, 09:11:07 AM »
Yes,
So far, every thing apart from the points has been renewed
Plus MJ and needle moved and adjusted
Really confusing
« Reply #101 on: March 25, 2023, 05:21:43 PM »
Right, issues cleared,out for a fine weather run,now running sweetly
I  replaced the coil with a cheap Chinese replica, £13 from Aliexpress,3.5 ohm primary circuit
Checked the cables to the condenser,
Fitted X24 Denso
Lo and behold, it finally ran as it should
« Reply #102 on: March 25, 2023, 06:08:54 PM »
Pleased to read it was sorted with an inexpensive coil fix.
« Reply #103 on: March 25, 2023, 06:18:06 PM »
Thanks Ted,
That's after mega bucks NOS airfilters,
Coils with higher resistance
Carb jets
Boy,it was a money pit
But glad I sorted it
« Reply #104 on: March 25, 2023, 06:47:44 PM »
Yes but you did need some air filters did you not?
We've all done it with petrol engines have we not?
I had a Manta GT/E that was a pig to start in winter having an early design Bosch fuel injection system. I started with plugs then plug caps then plug leads then coil. Changed the fuel filter then finally found a bad connection on the cold start injector. A squirt of contact cleaner - all sorted.
