Author Topic: 500 Headlamp size question ?  (Read 3103 times)
« on: December 12, 2022, 11:02:16 AM »
Can someone advise me as to how motor cycle headlamps diameters are measured as I will most likely fit a complete LED unit into the original 500 frame & housing if I can rather than using an LED bulb in a conventional reflector.
Am I correct in thinking the 500 is a standard 7" unit that you can generally fit other brands of reflectors into?
Re: 500 Headlamp size question ?
« Reply #1 on: December 12, 2022, 11:03:09 AM »
Yes
« Reply #2 on: December 12, 2022, 12:49:10 PM »
I've got a Cibie Z beam in my 500 Ted, along with a good LED bulb, the beam pattern is as good as identical with the halogen, so if the present reflector is ok try a decent LED bulb first. There is a thread about it on the site with pics. http://www.sohc.co.uk/index.php/topic,25595.msg234557.html#msg234557
Offline SteveW
« Reply #3 on: December 12, 2022, 01:07:46 PM »
I bought a pair of classic mini headlights for about £30. One fitted perfectly in my 550 without any problems.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #4 on: December 12, 2022, 06:25:15 PM »
How fortuitous is that? I was only measuring my headlight last night thinking how enormous it is..........Its a monster! ;D
« Reply #5 on: December 12, 2022, 06:25:33 PM »
« Reply #6 on: December 12, 2022, 09:01:14 PM »
That Haynes manual looks well used Roo
« Reply #7 on: December 12, 2022, 10:18:21 PM »
It is... I have a good copy in the house and a dissolvable one in the workshop. The poor thing's threadbare ;D
