Author Topic: Front Sprocket  (Read 11736 times)
Offline NICKYBOY
Front Sprocket
« on: December 22, 2022, 07:55:50 AM »
Hi all.
I need a 525 front sprocket for my CB650Z 1981, any ideas where i might get one. Standard is 530 !
Thanks.
Re: Front Sprocket
« Reply #1 on: December 22, 2022, 08:29:02 AM »
Is it for a special/modded application, as they are all but the same sprocket apart from thickness. You could get a 530 skimmed to 525 specification as one off to get you there.
Offline NICKYBOY
Re: Front Sprocket
« Reply #2 on: December 22, 2022, 09:12:57 AM »
Yes its to match the rear, from a vfr 400. I can get a 520 rear and also a 520 front (to fit a 500/4) from davies motorsport. Do you know if a front sprocket from a 500/4 will fit a 650 ?
Re: Front Sprocket
« Reply #3 on: December 22, 2022, 09:42:03 AM »
It's very likely to fit but I've no specific experience to offer regarding this. Obviously engine is derivative of 500 with things like this often transferable.
Sounds like a good mod as current 0-ring chains in smaller than original sizes easily seem to have the capability/rating of the torque produced.
Hopefully someone on here has the detail to help and will chime in.
