Author Topic: Removing dents with a steel ball and a magnet  (Read 3034 times)
Offline SteveW
« on: January 10, 2023, 04:08:09 PM »
Was flicking tv channels yesterday and caught an old episode of The Repair Shop.
Guy was fixing dents in the tube of a vintage telescope with a ball bearing probably in excess of an inch diameter on the inside and a large magnet on the outside.
He said the magnet had a pull of 26kg and he slowly massaged the dents out by working the ball over the dent with the magnet.
Wonder if this would work on fuel tanks, exhausts etc. I appreciate the metal is probably thicker but might be worth a go.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Removing dents with a steel ball and a magnet
« Reply #1 on: January 10, 2023, 04:28:20 PM »
I saw that Steve. I'd like to try that. The magnet looked quite small for the power, was it an electromagnet?
Offline SteveW
« Reply #2 on: January 10, 2023, 04:58:58 PM »
No, just a permanent magnet.
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #3 on: January 10, 2023, 05:09:26 PM »
I guess you are still left with the other problem of stretched metal to hide.
My 500 has a nice crease on the left hand front where the front fork looks as though it has met the tank - also the old column had the bent lock stop. Not sure if they are related.
In the 1970s lead filler would have sorted it - it was great stuff to work with back in the day but not on fuel tanks!
« Reply #4 on: January 10, 2023, 05:35:08 PM »
Any dent removal is down to the type of metal, the thickness and the access to the rear of a dent.  ;)
Offline Moorey
« Reply #5 on: January 10, 2023, 08:30:09 PM »
  Was the telescope tube brass and non ferrous.
« Reply #6 on: January 10, 2023, 08:45:16 PM »
Yes.
Offline Moorey
« Reply #7 on: January 10, 2023, 09:26:53 PM »
   Then I would think most of the magnetic force would be lost to the tank and virtually no control over the bearing inside. Try it on a biscuit tin.
Offline Rozabikes Tim
« Reply #8 on: January 10, 2023, 09:40:50 PM »
Also thin walled and relatively soft?
