Author Topic: General part number decipher  (Read 3403 times)
Offline Jan B
  • Everything you can leave behind is a gain
« on: February 25, 2023, 08:49:58 PM »
Already trying all evening to find a post where part number code's for general parts are explained. How can one tell if a hex bolt is chromed or zinc plated from the part number?
General part numbers have this format:
xxxxx-xxxxx-yy
I am interested in the YY designation. I've seen 4J, OA, OB, O2, O7 etc. I am assuming that OB means chromed. Is that correct? And does this also apply on nuts and washers?
Cheers.
CB500K1
CB750K2 [project]
BMW F800GS
Re: General part number decipher
« Reply #1 on: February 25, 2023, 11:54:00 PM »
Each of those codes stand for something like chrome, black, bzp, etc. There may be a list of what stands for what but not sure I’ve ever seen one.
« Reply #2 on: February 26, 2023, 10:11:47 AM »
As far as I know 0A is zinc plated, 0B is chrome painted , 4J is stainless steel (SS is rare on old Hondas  but  such things as the CB750K0 gauge clamp and exhaust heatshield retainers are stainless. e.g. 93500-05020-4J
There is also a -01 and -02 extension on spoke set part numbers .. some spoke nipples  are  nickel plated brass  (CB450K0 bomber, CB92 etc) and most are  carbon steel with zinc or nickel/zinc plating.
Different nomenclature on frame parts -XW is chrome, -B is black painted etc.
« Last Edit: February 26, 2023, 10:47:10 AM by AshimotoK0 »
« Reply #3 on: February 26, 2023, 11:35:53 AM »
07 seems to be black with captive spring and flat washer.
Offline Jan B
« Reply #4 on: February 26, 2023, 12:10:08 PM »
Thanks guys, that helps a lot.
Regarding the spoke nipples i know that early CB750K2 had zinc plated and yellow passivate whilst later ones were blue passivated.
CB500K1
CB750K2 [project]
BMW F800GS
Offline Seabeowner
« Reply #5 on: February 26, 2023, 07:33:09 PM »
I've bookmarked this site from CMSNL as it has lots of info:
https://www.cmsnl.com/help/faq/14_honda/#f14
Plus this I picked up somewhere so not 100% guaranteed.
CODE SUFFIX 1st digit MATERIAL
0=High Carbon Steel
1=Carbon Steel
3=Brass
4=Stainless
CODE SUFFIX 2nd digit SURFACE TREATMENT
A= Zinc Plate (White)
0= Zinc Plate (White)
B= Chrome Plate
2= Chrome Plate
C= Nickel Plate
3= Nickel Plate
H= Zinc Plate (Yellow)
8= Zinc Plate (Yellow)
J= Untreated
9=Untreated
G=Black
7=Black
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Erny
  • CB750K7 CB550K1
« Reply #6 on: February 26, 2023, 08:03:01 PM »
Very interesting and valuable info, thanks for sharing!
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline Jan B
« Reply #7 on: February 27, 2023, 10:18:40 PM »
This helps a lot in sourcing the right fasteners. Thanks for sharing!
« Last Edit: February 27, 2023, 10:24:05 PM by Jan B »
CB500K1
CB750K2 [project]
BMW F800GS
