Author Topic: Clutch push rod question ?  (Read 10950 times)
« on: March 05, 2023, 03:13:12 PM »
One end of my clutch pushrod is corroded quite badly on the outer surface does this matter or must I replace it?
If its okay to use what is the best way to protect it from becoming worse?
.clutch pushrod by Macabe Thiele, on Flickr
Re: Clutch push rod question ?
« Reply #1 on: March 05, 2023, 03:43:38 PM »
Are they expensive Ted?
Could you clean it up then heat treat it to case harden. I wonder if hard chroming is possible?
« Reply #2 on: March 05, 2023, 03:44:21 PM »
You can clean the rust off Ted with no problem. The problem area is where the seal sits on the chrome part, any wear or scoring causes a leak.
« Reply #3 on: March 05, 2023, 04:55:02 PM »
DS show no longer available plus they are I believe made from three parts with the centre section being a tube.
« Reply #4 on: March 05, 2023, 05:01:14 PM »
The corrosion has just started to creep into the last but one section so getting closer to the seal area  I guess.
« Reply #5 on: March 05, 2023, 05:02:33 PM »
To conserve the corrosion part, you could stand that end in rust converter fluid to stabilise, then just coat it in marine grease when installed to stop further deterioration.
« Reply #6 on: March 05, 2023, 05:04:54 PM »
You have read my mind I've already  dipped it in Evaporust overnight then Blued the end for protection.
Offline Seabeowner
« Reply #7 on: March 05, 2023, 06:50:08 PM »
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #8 on: March 05, 2023, 06:54:41 PM »
You should be able to get it hard chromed Ted, I had mine done as it was as skanky as that one you're holding. Came out great and was about 35 quid I think.
Someone on here had some carb connecting bars done that looked ace, might have been Ken but have a look Iit might be on his back after 30 years thread I think........
« Reply #9 on: March 05, 2023, 08:54:28 PM »
Difficult to chrome as the ends are steel but the middle ally as i remember, Honda did do a complete steel one but the clutch action was slow
« Reply #10 on: March 05, 2023, 09:04:01 PM »
It was me Roo, it cost me £23 at the time iirc, just had 2 done a few weeks ago for the princely sum of £152.
As Bryan says they are a composite rod so not suitable I’d say for hard chroming.
« Reply #11 on: March 05, 2023, 10:03:44 PM »
eek, thats dear isnt it?
There you go Ted, get after it with the 2000 grit :o
« Reply #12 on: March 06, 2023, 10:38:34 AM »
Found an aftermarket direct replacement on CSML.
« Reply #13 on: March 06, 2023, 11:08:54 AM »
CB500T pushrod (combined alloy and steel) is same as later 500 four pushrod.
Original 500K0 part was a 450 part and solid  steel .. as was fitted on my 3/71 500K0 but I got a later one from 'BJMCaferacer' on eBay after an argument with about him sending it in two pieces and he claimed I was talking bollox about it being a one piece push-rod, as the one he first sent me was in fact a broken one.
« Reply #14 on: March 06, 2023, 11:26:23 AM »
So many sellers believe its two piece
